LOTS of smoke at idle
Posted: Sun May 11, 2008 12:11 pm
by Engineer
went to dunedin yesterday from invers just for a day trip,middle of the main street my truck just starts spewing whitey bluey smoke out at idle! outta no where!i couldnt believe it, lights changed and drove to find somewhere to pull over and it stoped, then idling again it repeated itself!! i parked up amd checked water an oil and it all seems ok..?? what could this be?
had to get a mate to bring salavge trailer up and bring me home, i wasnt gunna drive it back.
its a 2lte.
any idea will be great.
cheers ryan
Re: LOTS of smoke at idle
Posted: Sun May 11, 2008 12:21 pm
by nstg8a
Engineer wrote:went to dunedin yesterday from invers just for a day trip,middle of the main street my truck just starts spewing whitey bluey smoke out at idle! outta no where!i couldnt believe it, lights changed and drove to find somewhere to pull over and it stoped, then idling again it repeated itself!! i parked up amd checked water an oil and it all seems ok..?? what could this be?
its a 2lte.
cheers ryan
what was the temp doing?
being a 2lte id be picking the common problem and saying you have head problems... weird that it only does it at idle though...
Posted: Sun May 11, 2008 12:39 pm
by Engineer
temp was sitting where it normally does.
ryan
Posted: Sun May 11, 2008 4:59 pm
by Dak
Turbo has sucked the big kumera I'd say.
Posted: Sun May 11, 2008 6:22 pm
by Engineer
yea thats what im thinking too. it used more gas on the trip than it normally would too!
Posted: Sun May 11, 2008 8:20 pm
by tweake
leak in fuel pump can look the same.
Posted: Mon May 12, 2008 6:17 pm
by Engineer
yea thats true might be sucking air? 2 yr ago i got it overhauled bcos of that new diesel hmm been thinking it could be a f**ked injector, burning excess diesel in the exhaust when idling as the excess diesel wont be getting burnt?
gunna take it to diesel shop an get them to check it out and probably just get them to fix it. while theyre at it they can do tappets, a noisey idler and injectors.
hmm
more i think bout it i dont think it will be the turbo as theyre pretty reliable and it doesnt add up to be that.
however after queens birthday ill pull the turbo out and overhaul it as it is getting abit noisier that it use to be. anyone know if i can buy a kit for the ct20?? seals and bearings etc? id rather not buy 2nd hand as it could be in the same state or worse.
regards
ryan.
if for some reason it is the head (unlikey hopefully) then ill go and throw that lexus in that i was gunna do last year hehe
Posted: Mon May 12, 2008 7:20 pm
by tweake
noisy idler ?? hope idler hasn't stuffed out and cam or injection pump slipped a tooth.
Posted: Mon May 12, 2008 7:38 pm
by Engineer
tweake wrote:noisy idler ?? hope idler hasn't stuffed out and cam or injection pump slipped a tooth.
same!
well its at the mechanic now, theyre gunna look at it over the next couple days..fingers crossed.
Posted: Tue May 13, 2008 5:04 pm
by swampa
if it poked i know of a 1kz that could be for sale in invers, it wont be cheap though but comes with 2 prado trans?
Posted: Tue May 13, 2008 5:22 pm
by timotheus
Engineer wrote:probably just get them to fix it. while theyre at it they can do tappets, a noisey idler and injectors.
hmm
Its common knowledge that those engines are shithouse. Spending lots of small amounts on a engine can often be more of a hassle than the one off payment of a upgrade.
Think about the 400km you had your mate do for you the other day. It all adds up.
You could use your pump on the KZ swamper suggested to get rid of the efi jazz. More power reliably.
Posted: Tue May 13, 2008 7:00 pm
by Engineer
hmm turbos on its way out big time, injectors buggard, tappets need done bad and its a noisy aircon idler (thats alright).
But to get them to do it itll be $2500!!
For me to rekit the turbo (if i dont have to replace housing etc) will be $500, tappets as theyre the shim time could possibly be afew hours work and $15 per shim, for me to replace with overhauled injectors $380, for me to do idler would be the cost of the idler. so maybe $1200 at most?? to then later on go and crack the head!!
very tempting to do the lexus or commy v6, itd be a good experience i reckon.
hmm dont know what to do
Ryan
Posted: Wed May 14, 2008 10:40 pm
by Petemcc
get yourself a 3vze like all the other boys ryan
Posted: Thu May 15, 2008 8:24 pm
by Engineer
Posted: Thu May 15, 2008 9:27 pm
by NJV6
You have the motor to do it, obviously wanted to do it, now you have the excuse to do it.......
So sing out when you need a hand to DO IT!
Posted: Thu May 15, 2008 10:17 pm
by Engineer
NJV6 wrote:You have the motor to do it, obviously wanted to do it, now you have the excuse to do it.......
i HAD the motor it went back as it was shagged and by the time the engine guy got me a minter it ws couple months down the track n lost interesr so i neva bothered getting it.
at the moment just gunna rekit the turbo. just tossing up whether or not i should do the injectors. $400 and unsure on the gains? would i get the money back in fuel effiency? any increase in (lack of) performance? im guessing i wouldnt. and it is a skanky diesel after all.
ohh and whats EGR? ive heard ya should remove it?what is this and whats th advantage of removing it?
Ryan
Posted: Mon May 26, 2008 10:41 pm
by Engineer
HEEEELP
ok got thr truck back together started bleeding the injectors and the hand pump started leaking fuel?!
now that cant be good if its leaking fuel itll be sucking air and not getting e anywhere is that right? please help i need tis piece of shit going before the thursday night!!!
im very tempted to get it going and trade it in!!! the amount of money ive put into it has been ridiculous over the last 2 years not including tires, lockers etc etc.
regards
ryan
p.s i must not be far away from having complete a mechanics apprenticeship surely the amount of work ive had to do on vehicles this past year lol. all good fun
Posted: Mon May 26, 2008 11:05 pm
by Petemcc
how bad is the hand pump leaking. i am pretty sure that the hand pump side will be high volume low pressure so it might not be sucking in too much air. and it is being pumped in not sucked in so it would more likely push fuel out rather than suck air in.
Posted: Thu May 29, 2008 1:02 am
by Engineer
right its 1am ive had a ***t of a night, had all four injectors flowing fuel but this bitch still wouldnt start, i bleed the injectors, injector pump, had to put a large pipe on primer pump and pressurize the tank then suck fuel thru because the primer doesnt wanna do its job!! ive replaced the primer. it just doesnt wnna get fuel to it.
neone have any ideas? whats stoping it from going if i had fuel to all injectors?!
i dont have fuel there anymore it like ran out! i dont know why ive still got 1/4 of a tank left.
please help me i have to have it going by tomorrow night!! im going to sweet talk the diesel workshops and just see if any on them can suss it out for me im right out of ideas!!!!!!!!!
not good, it should be so simple!!
Any help would be great.
Ryan.
Posted: Thu May 29, 2008 6:06 pm
by Engineer
never mind shes all go. we'l be going 4wdn this weekend!! yee haa. still got acouple wee things to tidy up on it tonight and tomorrow and she'll be all go!!
Cheers ryan.
Posted: Fri May 30, 2008 1:21 pm
by Heath
So what was wrong with it?
