wanted safari bits
- cool__bananas
wanted safari bits
hi all, i am in need of a rear diff and rear suspension arms, its a nissan safari SWB. when it gets rolling we can start with new motor
Re: wanted safari bits
hi
got a rear axle complete minus brakes with lsd 4.1 ratio
no suspension arms thou,but they are easy to get
Vince
Vince
- TheDarkSide
- Bush Crasher
Hey
Ive got a complete diff and all four arms (1 slightly bent). If your keen PM me.
Pete
Pete
- safari_mulisha
i have rear diff and all arms aswell as well as a 1994 td42 with less than 200ks on it
how did ya dad manage that mitch
There are 3 4.1 ratio rear diffs in yellow plastic bags out the back in my workshop help yourself you will have to swap the factory rear locker out though.
There are arms under the bench that the mill sits on too. Dad is down this weekend so go grab them then.
Take 2 of the shorter arms and get brian to make up some new ones using the ends. Make them 16mm longer than the factory bottom arms.
Hello from Rome!
Hello from Rome!
MWB V8 Safari Ute
Hi Jarod
Yes Roger has damaged his truck big time - it happened on the first stage of the Central Zone Teams Challenge in Whitemans valley Sat 3/5. Large rocks hidden below water tore the rear end although he did manage to winch his truck up through the blue pegs to complete the hazard. That was the end of the mighty Nissan - dead as, trallered home on Sat night, backup truck didnt last the distance either, so in came Charles truck which also failed to make it, so the team finished with only two trucks running. Valley club won the event, second was the TePuke boys
Talk is now that Mitch is losing his trials truck to dAd - but dad will build a new trials for Mitch
Hope you are having fun in Rome, when are you home
2001 Mitsubishi Diamante VRX Sport
- cool__bananas
worthog wrote:Talk is now that Mitch is losing his trials truck to dAd
hes to scared to drive it. so im not losing it yet. and the whole reason he might get it is because of the new truck
