max offset for 93 pajero?
Posted: Sun May 11, 2008 11:17 pm
by xj
Not that i actually own one.... BUT.... can a 92 Paj with 40mm body lift take an 8x15 rim with a -95 offset?
Re: max offset for 93 pajero?
Posted: Sun May 11, 2008 11:38 pm
by xj
actually backspace all of that. just done some math. a 95mm offset on an 8 inch rim would leave 7.62mm of rim left on the back.... surely thats not possible
So what offset can a Paj take?
Posted: Mon May 12, 2008 7:22 am
by NJV6
Sorry I can't help you with the numbers but a Landcruiser or solid axle hilux one sticks out on a Pajero and may just scrap in without needing to add to the factory flares. They also tend to get a bit close to the guards at the rear of the front wheels when it is compressing and turning with a full size 33.
Std nissan offset works fine but I don't know what they measure.
Posted: Mon May 12, 2008 7:36 am
by skid
xj wrote:actually backspace all of that. just done some math. a 95mm offset on an 8 inch rim would leave 7.62mm of rim left on the back.... surely thats not possible
from wot you are saying it sounds you have a rim with about 18-20 positive offset. it could fit but will sit under the guards a wee bit
as always try it on first
