TD27T EGR Removal
Posted: Tue May 13, 2008 9:27 pm
by Dr Rocket
I have just finished changing the injector pump on my 1990 terrano TD27t and in the process I removed the EGR valve and the butterfly actuator. I also made up blanking plates for where the EGR valve was located. I took a lot of photos and also scanned the drawing of the blanking plate with dimensions.
If anyone wants the photos email me at
lesday@wn.com.au and I will send them to you.
Regards Les.
Re: TD27T EGR Removal
Posted: Tue May 13, 2008 9:43 pm
by tweake
upload them to a free photo hosting such as
http://photobucket.com/ and post the links
Posted: Tue May 13, 2008 10:55 pm
by Dr Rocket
Iv'e made them into PDF word documents with descriptions so they will be easy to email.
Posted: Thu May 29, 2008 9:31 pm
by long
did you find you have more power by blocking it off i know mine seams to have more ?
Posted: Fri May 30, 2008 12:16 pm
by Dr Rocket
It has got more power but it is hard to tell if that is what did the trick as I cleaned out the inlet manifold, added a catch tank for the blowby removed the EGR and replaced and retimed the injector pump all at the same time.I am still running it on 50% used engine oil and the other day I had it up to 150kph!
Posted: Sun Jun 01, 2008 10:05 pm
by tweake
disablin egr will not increase max power as its normally not on at full throttle, unless its faulty which is fairly common.
however you will notice part throttle is a lot better.
