lift my truck
lift my truck
hay im trying 2 lift my 88 pojero 2l turbo swb i know how 2 lift the back thats easy but i need 2 change the frount wish bones but i dont know how or what 2 buy can you help with that
Re: lift my truck
change the wish bones? are you trying to lift it or gain extra track? you dont need new wish bones to lift it. how high do you want to go?
Sam
Sam
Re: lift my truck
iv got it right up on the stops and id like 2 go about 80-100 mm
Re: lift my truck
hey bro put up where you live on your signature file as someone my live close to help you out
Re: lift my truck
im not sure if you can on the older models, but have you done the ball joint flip on the front upper arms? if you havent you can get more lift from that, but even then i doubt you will get 100mm. ill try find a link to the balljoint flip for ya.
Sam
Sam
Re: lift my truck
Don't forget that you will need to get the vehicle certified for those modifications.
Re: lift my truck
If you want to go another 70 to 100mm above what you have now which if you are on the bump stops will be about 3 inchs you have the wrong vehicle.
Without spending mega bucks redoing the entire front end, lowering the diff etc it won't work. THe Ball joint flip cannot be done on your vehicle unless you change to gen 2 upper wishbones but this puts your camber waaaay out.
Get a solid axle front or a vehicle that already comes with one.
If you want bigger tyres, a body lift would make lots more sense and wind your torsions down a bit - it is dangerous driving on them fully wound up.
Have you heard of punctuation in your writing?
