I have to attach the exhaust manifold on my toy and there are only three studs left in the head. Can I use bolts instead of studs and what sort should I use (8.8,12.4, or whatever)
Heath
studs or bolts
Re: studs or bolts
My Isuzu uses 2 studs as locators and the rest of them are bolts.
As to HT or not ... I'm not sure ... I would guess that as they are normally torqued down they would be HT
Re: studs or bolts
Use studs with a brass double nut. [ extra long nut ] the brass nut won't rust to the stud.
Re: studs or bolts
just looked in my haynes book and they are a few studs and the rest bolts. Now to sort what bolts.
