hilux 2inch lift
Posted: Tue May 27, 2008 9:44 pm
by waugu
Can neone shed som light on this for me??
I just finished installing my new maxitrac springs, longtravel shocks and new u-bolts, problem is the steering arm still hits the spring even with the new u-bolts in. I used all maxitrac products. Is ther a way to remedy this problem with bolt on parts?
Re: hilux 2inch lift
Posted: Wed May 28, 2008 9:01 am
by SupraLux
Did you use the flat-top u-bolt or a new round one? There is a special Maxitrac flat top one to go on the rear of the drivers side pair.
If it is still hitting, and they are H-spec springs then you probably have a bent steering arm, which will need replacing (they are not cheap, and because of this I have seen them bent back to resolve it but I strongly recommend against that - weakening the material that holds your steering together just isn't a good idea).
Steve
Posted: Wed May 28, 2008 5:37 pm
by waugu
i asked for flat top u-bolts and the ones they gave me have flat edges and they still hit the steering arm you are talking bout is this the c shaped arm or the drag link? I have seen drop drag links that are suposed to fix the prob by making the drag link parallel with the spring again but when I look at it even with it parralel I think it would still hit? If its the steering arm I will replace it I just need to know exactly which one your talking bout? thanks
Posted: Thu May 29, 2008 7:45 am
by Bulletproof
waugu wrote:i asked for flat top u-bolts and the ones they gave me have flat edges and they still hit the steering arm you are talking bout is this the c shaped arm or the drag link? I have seen drop drag links that are suposed to fix the prob by making the drag link parallel with the spring again but when I look at it even with it parralel I think it would still hit? If its the steering arm I will replace it I just need to know exactly which one your talking bout? thanks
You are better to put a drop arm on anyway, beause the ordinary arm strains the end ball of the C arm and will break it off.
I have seen it happen 6 times and to lose steering is not a nice feeling.
The better option is to use cross over steering using a surf box if your tyres arn't too big. I have used a cruiser steering box which is a lot heavier because the surf ones blow seals with big tyres.
bulletproof
Posted: Fri May 30, 2008 9:41 am
by SupraLux
Ok. Sorry I probably wasn't clear - all the u-bolts are flat on top rather than round as they go over the springs and need to be, but the "flat top" ubolt looks like all the rest, only the top bit that goes over the spring has been compressed in a press during manufacture so instead of having a round profile its oval and thinner to stop the end of the drag link clipping it on the way through.
If you need one and can't get one locally I have some in stock.
If your J-arm is bent (as they sometimes get) too much, then even this won't stop the clipping - and the J-arm needs to be replaced - or you can replace the drag link with a bent one (good luck getting it past the cert guy tho - I know they have been failed before)
Alternatively a mod like this can fix it, and this is certifiable (or was last time I put a truck with it on through)
http://www.4wdstuff.co.nz/node/94Steve
Posted: Fri May 30, 2008 9:49 am
by SupraLux
There is a pic of the flat top u-bolt here for reference:
http://www.4wdstuff.co.nz/files/flat-top-u-bolt.jpg
Posted: Fri May 30, 2008 12:04 pm
by rokhound
Go the crossover option. You need an IFS surf steering box, high steer arms (see jafa from here) and a few other bits and bobs. This mod takes away some nasty habits that the standard setup has.
Don't know about seals blowing out on std surf steering boxes, I run 39.5 " tyres and have never had a problem with seals blowing out.
Posted: Sun Jun 01, 2008 11:36 am
by MATT4U
the only time I had a seal blow out was when I had the bump stops wrong and hit the pitman arm with the spring
Posted: Sun Jun 01, 2008 11:39 am
by Chopper01
Bulletproof wrote:The better option is to use cross over steering using a surf box if your tyres arn't too big. I have used a cruiser steering box which is a lot heavier because the surf ones blow seals with big tyres.
bulletproof
I run 37's and have never had a seal blow out on a power steering box
Posted: Thu Jun 05, 2008 6:14 pm
by Poacher-HILUX
Gday there. please inform me more about how you change your steering arm so you can run more leafs in the front?
Posted: Thu Jun 05, 2008 8:36 pm
by SupraLux
Poacher-HILUX wrote:Gday there. please inform me more about how you change your steering arm so you can run more leafs in the front?
SupraLux wrote:Alternatively a mod like this can fix it, and this is certifiable (or was last time I put a truck with it on through)
Thats as good as the info gets for now... I do these conversions though if you are interested in having it done
Steve
Posted: Thu Jun 05, 2008 9:09 pm
by Smurf
here is a pic of my modified draglink, not sure if it is any clearer than Steves one...
I can get a better pic if anyone is interested.
Posted: Fri Jun 06, 2008 7:45 pm
by Poacher-HILUX
how much does this cost ?
Posted: Sat Jun 07, 2008 1:38 pm
by SupraLux
Are you looking to drive-in-drive-out or do you want a cost for the parts? The steering arm modified ready to go will probably cost you around $300...
Posted: Sat Jun 07, 2008 3:58 pm
by Poacher-HILUX
im in dunedin so its abit hard 2 drive in and drive out. so im looking at price for the parts
Posted: Sun Jun 08, 2008 7:46 pm
by waugu
thanks for the info, big help indeed! Pulled the j arm off along with the draglink taking them to my engineer this week hopefully be all back going again by the weekend! I hope!!
Posted: Sun Jun 08, 2008 8:07 pm
by SupraLux
Are you running that without the torque rod? That must be hell on the road when you hit the brakes
Steve
Smurf wrote:here is a pic of my modified draglink, not sure if it is any clearer than Steves one...
Posted: Sun Jun 08, 2008 8:43 pm
by Smurf
SupraLux wrote:Are you running that without the torque rod? That must be hell on the road when you hit the brakes
Steve
Yeah, Broke it a number of weeks ago, I needed to extend the bumpstop to stop it from hitting the engine mount and never got around to doing it. I did buy an adjustable torque rod too as the one in there was bent. but then decided to go X over.
Got all the bits to convert to X over steering now so didn't see the need to repair/replace the torque rod. But yeah it makes it interesting on the road thats for sure.
Posted: Thu Jun 19, 2008 7:34 pm
by waugu
Thanks for the info guys, I had the drag link modified and the ball joint fixed up, set me back $250 to have that done, fitted that now and the lux drives again!!! Wots the story with W.O.F with the drag link?? cert? and ware can I get an adjustable torque bar??
