http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Suzuki/auction-158031756.htm
89-95 Suzuki Vitara/Escudo Supercharger Kit
I have just supercharged my G16a 94 escudo, it runs 9psi and goes really really well. I have done over 1000kms with it on and no problems.
In saying this i CANNOT guarentee what damage it may do to your engine. I WILL NOT FIT FOR YOU.
*** Test drives are welcome***
This would be an excellent modification for 4x4 driving as the amount of torque it add is unreal.
And the best part is they have an electronic clutch on the pulley to turn ON and OFF when desired
The kit consist of the following;
1x SC12 Supercharger (1200cc per RPM)1x Head gasket
1x Head shim (to lower compression)
1x Belt
1x Blow of Valve (need to bleed boost on idle or when throtle butterfly is shut)
1x Bracket to bolt to exhust manifold
1x Bracket to replace Air Con bracket
6x 64mm Silacone bends
1x Pod filter
Intercooler will NOT be supplied.
And would require a good mechnical knowledge or help by one.
It would take approx 3 weeks to ship as would require time for parts and to make brackets.
Please feel free to ask any questions..
