MQ Rear diff Question
For all Nissan related topics
godzook
Post by godzook »
I just broke the rear diff in my bush bash safari and was wondering if there are any diferences in the ratio's between the l28 ld28 and the sd33
Re: MQ Rear diff Question
look for your ID plate, maybe on the firewall somewhere and get the axles codes off it and then start searching the net for a site that tells you how to decipher the codes.
there will be one somewhere, maybe even on here
if you had a toyota then I could have told you already
although I have a sneaky feeling that they will all be the smae anyway
SKID
