toyota diffs
toyota diffs
I need to know are the front and rear diff heads the same in my bj74 cruiser ? I have pulled the rear complete unit out and replaced with a disc braked lsd and am about to have an arb fitted to the front, would prefer to send in my (now spare) original rear diff for fitting so ,y truck does not need to be off the road, (then I can just swap them over one night / weekend) rather than have it sitting in the shed un drivable for a week or so. cheers
If you follow me in the bush you must be mad cause I'm plain CRAZY !!!
1987 BJ74, 13BT, Auto, 35" Wranglers, 80mm Suspension Lift, 2" body lift, LSD rear, ARB Front Locker, PTO, Lots of Steel and a Go Hard Driver.
Re: toyota diffs
They should be the same as my BJ70..same diff heads/3rd members front and rear..cheerss
Re: toyota diffs
champion thanks for that. presumed they were the same.
