HI
Has anyone got an adjustable safari panhard they want to sell?. Trucks crabbing a bit down the road.
Doug...
GQ adjustable panhard Rod wanted
Re: GQ adjustable panhard Rod wanted
Should be able to just mod your existing one, or Mudhunt has a mate in ChCh that sells an adjustable insert you can put in
DaveM wrote:Should be able to just mod your existing one, or Mudhunt has a mate in ChCh that sells an adjustable insert you can put in
Swamped do you want his number his name is Steve,pm if you want it
Vince
I would like those details as well. Did you manage to see if you had a front left hand indicator.
Al
Al
Yeah his details would be good. I've seen modified rods with the adjustable part off a hilux inserted.
- safari_mulisha
standard ones are still crap
they bend easy as
just spend the cash on an aftermarket one
they bend easy as
