remote trans coolers
Posted: Fri Jun 06, 2008 5:00 pm
by 97prado
Hi.
Can any one suggest a good remote trans cooler for the Prado??
Re: remote trans coolers
Posted: Fri Jun 06, 2008 5:03 pm
by rokhound
I would have thought anything that helps keep the auto cool over and above the std cooler would be good. BNT carry auto coolers, or you could try your local radiator shop or auto trans repairer
Posted: Fri Jun 06, 2008 5:32 pm
by kiwipete
I got my one for the Terrano from BNT as they were the best option then. It's about A4 size, being the second to largest size and works well, although a little too well on frosty mornings. I need a blind for it. :?
Posted: Fri Jun 06, 2008 6:02 pm
by TJ
kiwipete wrote:I got my one for the Terrano from BNT as they were the best option then. It's about A4 size, being the second to largest size and works well, although a little too well on frosty mornings. I need a blind for it. :?
If you still have the factory radiator, you should route your extra cooler like:
- Out of tranny --> into auxiliary cooler
- Out of aux cooler --> into radiator cooler
- Out of radiator cooler --> back into tranny
That way, if the oil is too cold, the radiator cooler warms it up a little. Also, buy a cooler that has a bypass built into. That way the oil is bypassed from the cooler unless its hot enough that it needs additional cooling. B&M Coolers are like that.
Posted: Fri Jun 06, 2008 7:59 pm
by tweake
you doing the radiator mod the surfs usually do ? (remove or cut down the trans cooler in the radiator to help with motor cooling).
the bypass thermostat is a very good idea. if the cooler doesn't come with one you can get them as a separate item. its lets the auto warm up to temp otherwise you can run into problems with overly cool trans fluid.
Posted: Fri Jun 06, 2008 10:18 pm
by kiwipete
Tweakie and TJ, these hints n tips I know already but thanks anyway.
My cooler didn't come with a bypass thermostat, I am waiting for the auto tranny place to get one in so it can be added to the system.
Must ring them again re this.
Posted: Fri Jun 06, 2008 10:49 pm
by rokhound
kiwipete wrote:Tweakie and TJ, these hints n tips I know already but thanks anyway.
Has it taken a while then Pete?
How muchie are these and can you get them anywhere else?
(need to get all the bits together before I start the new rig :D )
Posted: Sat Jun 07, 2008 10:49 am
by BIGK
ya looking at $150-200 for a new cooler to suit...
ea falcons etc have decent size coolers aswell(got one from pickapart.$20.00)and just gave it a flush which really wasent needed...
