Apologies for those with dialup - theres a few photos here...
In 2WD, this is as high as I could drive it on 31" all terrains without slipping on the grass - and I didn't want to damage the passenger side spring. It shows potential tho I think... I have my 36" Simexes now, but I'll wait till the shocks and crossmember are done before pulling it out again...
And from side on:
Then a closeup of the front wheel arch showing how much more droop I can get:
In the rear the springs are standard 50mm lifted Isuzu ones until I can get some falcons shoe-horned in there. These are on standard spring hangers, which I will swap out for extended ones to level the truck a bit:
Another angle:
And the problem: Damn crossmember in the way. Still, I have the modified one I made - now I just need to fit the darn thing...
Steve...
