Hi.
Anyone put in a Fuelstar system?
fuelstar
Re: fuelstar
http://www.immortality.co.nz/fuelstar%2 ... ience.html
says it all. no doubt any performance increase peole see is due to the installer advancing the timing !
also its for petrol vechiles not deisel.
Re: fuelstar
It'll lighten your wallet, which may result in some tiny fuel savings.
Re: fuelstar
yes but only removing such a small weight from the wallet but adding a few grams under the hhod could actually decrease fuel eccon.....
If you follow me in the bush you must be mad cause I'm plain CRAZY !!!
1987 BJ74, 13BT, Auto, 35" Wranglers, 80mm Suspension Lift, 2" body lift, LSD rear, ARB Front Locker, PTO, Lots of Steel and a Go Hard Driver.
