jeep stud pattern and electric windows in jeep xj
Posted: Tue Jun 10, 2008 3:05 pm
by mudhunt
Hey my mate has just bought a cherokee and wants to put his 33"s on it, its got a 4.5"lift so we will need to cut the guards a bit. ANyway currently it runs wrangler31s and on the standard steel jeep rims. It rubs a little in the back on flex so we guna need offset rims. What offset to get? does the jeep 5 stud pattern match the suzuki by any chance? Also electric windows playing up they go down but very slowly but then wont go back up. It seems that maybe there isnt enough power getting to them???they all the same
Re: jeep stud pattern and electric windows in jeep xj
Posted: Tue Jun 10, 2008 5:19 pm
by Cloggy_NZ
mudhunt wrote: does the jeep 5 stud pattern match the suzuki by any chance?
Early Jeeps did which had the 5 stud 139.7mm PCD. However modern Jeeps including the Cherokee and Wrangler have 5 stud 114.3mm PCD I believe.(I used to own a Lada Niva which had the same stud pattern as early Jeep and Suzuki).
Modern Jeep is the same as Hilux 2WD only, Chrysler Valiant, Ford Falcon etc. although these only run 14" wheels.
Posted: Tue Jun 10, 2008 5:47 pm
by skid
somewhere around here is the thread you're after
this has been discussed on here before
I know of a guy in Taupo who fitted 33s with no lift at all and only minor inner guard trimming
Posted: Tue Jun 10, 2008 6:14 pm
by TJ
Jeeps never came out with metric stud patterns, so the actual stud patterns as far as I know are:
5 on 4.5" bolt pattern - Jeep XJ, YJ, TJ, ZJ, and KJ
5 on 5.5" bolt pattern - Jeep CJ
5 on 5" bolt pattern - Jeep WJ, WH and JK
You have to keep in mind backspacing as well on the rims. That is where things start becoming interesting.
Have a read of this
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=32&t=5679Also, this website is good for referencing as well:
http://wheels.customfastcars.com/find-your-stud-pattern.html
Posted: Mon Jun 30, 2008 7:52 pm
by minimun
does the xj stud pattern match the land rover discovery stud pattern?
Posted: Mon Jun 30, 2008 9:43 pm
by skid
minimun wrote:does the xj stud pattern match the land rover discovery stud pattern?
nup
Posted: Wed Jul 02, 2008 5:22 pm
by xj
114.3mm PCD
Posted: Wed Jul 02, 2008 6:09 pm
by skid
xj wrote:114.3mm PCD
thats one of them
Posted: Wed Jul 02, 2008 6:28 pm
by xj
yes it is
Posted: Wed Jul 02, 2008 6:41 pm
by skid
xj wrote:yes it is
and you know this aye
Posted: Wed Jul 02, 2008 8:06 pm
by xj
yes i do.... cause i is a bro-fessional
Posted: Wed Jul 02, 2008 9:35 pm
by skid
xj wrote:yes i do.... cause i is a bro-fessional
chuuurrrrr bro
keep up the good work ow
Posted: Mon Sep 15, 2008 8:49 pm
by xj
getting back to it... how did you get on?
-19 to -24mm offset ought to do the trick. Keep us posted aye?
