Shocks
For all Daihatsu related topics.
southland_Feroza
Shocks
Post by southland_Feroza »
I have a gotten a set of hilux shocks for my 1990 feroza but when the hilux shocks are compressed they are a bit longer then the original feroza ones. Will this be an issue for me??
DaveM
Re: Shocks
Post by DaveM »
Should be ok as long as your bumpstops are long enough to stop the shocks bottoming out at full compression
Heath
Re: Shocks
Post by Heath »
Put a packer in (between the bumpstop and chassi mount)to increase the height of the bumpstops so the shocks dont bottom out.
southland_Feroza
Re: Shocks
What should i use as a packer between the bumpstos and chassi
Heath
Re: Shocks
Post by Heath »
I made some up for my old suzuki from 12mm ali bar. Just shaped and drilled to fit and then used longer bolts. I guess steel flat bar would be okay also, just a little harder to work.
Return to “Daihatsu”
