To build high ground clearance kick arse syspension
Some of you may have seen the subarau brat that is doing the trails
How many times have you droped into a set of ruts only to get hung up on your diff's... answer bigger tires, but you only get half the increase in clearance!!
Why not move the diff head up... two options, planitary hubs to move the whole axle up (I haven't looked at this as I want a road going 4WD and my wallet isn't big enough
Bonus's, good road handling, and potential
Problems (to be overcome
My Design "breif"
To take commonly available products (cheap and easily sorced) mix and match with some engineering to produce a cheap modula unit that with some engineering should go up under most 4WD's
The diff head is to be centered and narrow to give the max room for the suspension arms, the longer the "A" arms are the longer the axles are and shallower the CV joint angle is and the greater the range of travel. The lower "A" arm will be level with the axle for max clearance. The new chassi section will go over the top of the CV at the diff and will use the diff for strength
How does it sound so far
The syspension is to be coil or
Now this is the bit where I need some help, the mix and match parts
I need the parts to be commonly available at wreakers, be strong! and be adaptable eg diff must be able to fit a locker, hubs to be 6 bolt so spare tire fits etc. Don't worry about compatability I'll deal to that
Heres what I'm working on at the moment
Diff - Hilux solid axle diff head, will fit a locker, resumbly strong and has a range of ratio's available at the wreakers
CV's - Hilux front drive shaft unit, just becouse I've got em
The rest well I'm open to your ideas
Please note this is going to take some time and I'm just starting to put things on paper it may be a while before it hits the shed and I've got to get the hilux done first
Looking forward to seeing what comes of this
Cheers Reece
