diffs heads
pajeroboy
diffs heads
Post by pajeroboy »
well looked ar my front diff today and low and behold broken teeth on crown wheel and pinion,result from last trip,woops, so since i have to replace it was curious if a rear diff head with a factory locker would fit into the front housing? provided i use same ratios, would this work?
33" muddies, 50mm body lift, ball joint flip, quick release front sway bar,40mm lifted rear dobi springs and new shocks,custom sill body armor,custom front bar.
SAM
WACKO
Pyro
Re: diffs heads
Post by WACKO »
nope. what engine is in yours? i have a couple of spare front diffs here.
the pajero rear is a 9inch , 3ltr v6 manuals have a 8inch front diff. the auto v6 and 2.5dt (5spd and auto) have a 7.25 inch front diff.
Sam
red-devil
Re: diffs heads
Post by red-devil »
Sam you can get lockers for the front. i've seen them in a auzzy site about $1700 aus. ill have a look and see if i can find it again and send it to you. Good luck. front iffs are easy to pull out. after doing the VX
http://www.arb.com.au/News/Internationa ... Locker.pdf
This one talks about them a little
http://www.outerlimits4x4.com/viewtopic.php?t=29441
Jono
NJV6
Re: diffs heads
Post by NJV6 »
Sam is right - won't work.
But as red devil suggests you can get replacement diff centres. Pajero boy - you have a 2,5 from memory with a 5.29 ratio... That is the smaller diff and so the diff lockers red devil talks about won't work either. Not without alot of work.
Well done on breaking the diff. That is a pretty sound effort! :lol: Were you being particually severe in reverse as I'd be surprised if you broke it going forwards with the reverse cut high pinion gears.
pajeroboy
Re: diffs heads
Post by pajeroboy »
well crap then, there goes that plain,are the lsd ones the same sizes as the locker ones?
yeah was buried up half way up the doors in muddy shingle shity stuff,hurd a bang and just thought is was a c.v kinda wish it was now :oops:
yeah its the 2.5 soft top model with the 5.29 ratio, just a shame that i cant just steel the one from red devils one :D
do you have one to fit wacko?
SAM
WACKO
Pyro
Re: diffs heads
Post by WACKO »
red-devil wrote:Sam you can get lockers for the front. i've seen them in a auzzy site about $1700 aus. ill have a look and see if i can find it again and send it to you. Good luck. front iffs are easy to pull out. after doing the VX
Jono
yes you can get lockers to fit, but you cant get a factroy rear locker to fit in the front.
pajeroboy wrote:do you have one to fit wacko?
yep ive got one here but im in wellyington so freight would be a bit steep. your prob better off searching trademe or the wreckers. but if you get stuck its here.
Sam
red-devil
Re: diffs heads
Post by red-devil »
did a little more looking sam sorry were out of luck need to have the v6 or the older modle :( you may be lucky with my front end, im starting to think about the that truck and were i should plan new truck or fix the motor.
jono
pajeroboy
Re: diffs heads
Post by pajeroboy »
yeah ganna have a looksey closer to home but at least there one there thanks Wacko.
ohh true what direction are you most likey looking into jono?
SAM
red-devil
Re: diffs heads
Post by red-devil »
not to shou yet , but mite get a fram hack and put the best of both into one
Return to “Mitsubishi”
