gq gearing
Posted: Mon Jun 16, 2008 11:34 am
by mudhunt
whats the best way to fix gearing in gqs when youre running 35s gears are a bit long in low range now with the 35s. Is it easier to change diffs or to change transfer case gears
Re: gq gearing
Posted: Mon Jun 16, 2008 11:51 am
by albundy
What ratios do you currently have in the diffs. Mine is 4.1:1 and I don't find it too bad with the 35's on.
Al
Re: gq gearing
Posted: Mon Jun 16, 2008 12:18 pm
by darinz
If you can get them, 4.625 ratios from a RD28 GQ will make the gearing (and so speed) the same as 4.1 (which is what you probably have) and 31's. The other option is a turbo!!
T"case ratios are not easy and they only change low range.
Cost if buying new aftermarket diff gears or t"case gears would be similar from memory.
Re: gq gearing
Posted: Mon Jun 16, 2008 9:17 pm
by mudhunt
what about the 3.0 litre gu? just i know where one is being wrecked?
Re: gq gearing
Posted: Tue Jun 17, 2008 5:52 pm
by DaveM
mudhunt wrote:what about the 3.0 litre gu? just i know where one is being wrecked?
Is this at a wreckers? My mates GU ZD30 ran 4.3 diffs, not sure if thats what they come with or not.
Re: gq gearing
Posted: Tue Jun 17, 2008 6:29 pm
by mudhunt
yeah it is at a wreckers and youre right they 4.3 found that out today.
Re: gq gearing
Posted: Tue Jun 17, 2008 6:31 pm
by DaveM
mudhunt wrote:yeah it is at a wreckers and youre right they 4.3 found that out today.
Which wreckers is it at? What type of damage?
Do you know if Steve got my email?
Re: gq gearing
Posted: Tue Jun 17, 2008 6:44 pm
by mudhunt
i get wreckers name for you tomorrow its had a brash but still has engine and running gear, havent talked to steve yet mate
