"ARB WINCH BAR"
"ARB WINCH BAR"
will fit KZN185 and VZN185 96 on surfs or 90 series prados,
air bag compatible, doe's not include winch
1980 4x4 Hilux Restoration
Re: "ARB WINCH BAR 4 SALE"
any pics? and is there a model no on the bar so I can see if it will fit my KZJ?
part number 3421050
i still have the fitting instructions,
you could modify excisting mounting brackets or make new ones to fit anything (anything is posible)
hi, do you still have it? where abouts are you?
i still have it , im in TeAroha
4runner wrote:hi, do you still have it? where abouts are you?
How much are you looking for?
Mattman wrote:How much are you looking for?
they are just under $2000 new, has a few sratches, make an offer
- flyingbrick
That looks like it fits real nice- i like how close it sits to the guard and grill
what size wheels and off set are you runnning on that surf? Cheers
koma wrote:what size wheels and off set are you runnning on that surf? Cheers
was running 265/75/16 , im unsure of offset of the rims cause i bought them 2nd hand
Cheers, did you need to lift it to run them or not? Those bars look sharp to, very tempting.Cheers
koma wrote:Cheers, did you need to lift it to run them or not? Those bars look sharp to, very tempting.Cheers
i had a 50mm suspension lift and a 25mm body lift and they still rubbed a little now and then
Re: "ARB WINCH BAR"
Just checking to confirm that this is the same bar as you had fitted to your surf? Cheers in advance. http://www.trademe.co.nz/Browse/Listing ... =289344136
Re: "ARB WINCH BAR"
Cheers, was preatty sure. What are these things worth new?
Re: "ARB WINCH BAR"
Hey Im looking at doing a 25mm body lift, did you run into any troubles in the process? Cheers in advance.
