Heath wrote:Is there any wonder why zuks crack their heads. Look at the crappy flow we zuk owners must get with these gaskets.
Most of the flow has to go through these little holes and you can see the actual shape of the water courses. Hell some of the holes arent even there or just line up (one was 50% obscured). Maybe we should use a hole punch and remove more material before fitting?
Heath
Be carefull opening out water holes in the gasket without good reason. You will probably find the holes are actully like that to controll the water flow through the engine and keep the temperature even across the head.
Notice there are more & larger holes in the top left of the pic than the bottom right.
Ben
