are 33 12.5 15 to big
muttly
Post by muttly »
hi i have a 1994 landcruiser prado with the 3.0 d t 1kzte motor your thoughts on putting on 33 12.5 15 on thanks
kaney
Re: are 33 12.5 15 to big
Post by kaney »
yep can be done on standard suspension as well
toymota thats stock standard.
UBZ
Post by UBZ »
im running 33 x 12.5 x 15 BFG with my 1KZ manual , heaps of power even without a diff ratio change.
Gets very hot though :shock: :shock: :!: Would defiantly recommend a temp gauge mod or aftermarket temp guage.
Bulletproof
Post by Bulletproof »
33x12.5 is the biggest size you can run without too much trouble. 35s require a diff change to 4.8 ratio or you run out of power .
Never say die, up man and try
Clint
Post by Clint »
I've got 33's on my LJ71, Sumitomos that actually measured up at 32" when new @ 30psi. They did rub occasionally at full lock/squish in the front & just hit the top of the wheel arch in the back on hard landings. With new 40mm higher springs & packing the bump stops down a touch no more probs.
Clint
UZJ71 Landcruiser
KTM 640
muttly
Post by muttly »
put 33 12.5 15 on and they are rubbing on full lock in the inside of tyre on the radious arm is there a cheap and easy way to fix this or are the tyres just to big
Heath
Post by Heath »
maybe one of those spacers (5mm think if my memroy serves me) would be enough to space them out. Dont know the legalities of the thin spacer (cert or not).
Chopper01
Rock God
Post by Chopper01 »
do they still make them that small :lol: :lol: :lol: but no they should be fine nothing a bit of masageing wont fix :mrgreen: :mrgreen:
Running 33" mudzilla's on my LJ71, runs fine, has a 2" OME suspension lift, no rubbing etc. my 2lte seems to push them ok so your 1kz shold move them nicely, PM markr or icedjohnno on here, they have ikz... ones and seem to know heaps
muttly
Post by muttly »
adjusted front bump stops no more rubbing :D :D :D :D
