hey guys im wanting to convert my 1.6l petrol rocky to a 2.8 turbo diesel from a rugger how hard would it be to do this? and how hard would it be to source an engine?
also would i need to get a bigger fuel tank?
diesel converstion
Re: diesel converstion
rockyman wrote:hey guys im wanting to convert my 1.6l petrol rocky to a 2.8 turbo diesel from a rugger how hard would it be to do this? and how hard would it be to source an engine?
Can i ask why? The Rugger 2.8 engines aint light, and may be a little to heavy for the smaller rockys, as the Ruggers are a bigger, and entirely different vehicle.
Whats wrong with the 1.6 anyway?
Go Hard or Go Home
would it work though? the 1.6 is a bit small and i want to keep the rocky so i thought id upgrade the engine what about a smaller daihatsu diesel engine?
are there any other 2.8l TDs that would fit in it? easily or without huge modifications
rockyman wrote:would it work though? the 1.6 is a bit rooted and i want to keep the rocky so i thought id upgrade the engine what about a smaller daihatsu diesel engine?
Anything is possible, just how much you want it, and how much your prepared to pay for it..
Personally, for a Rocky, i would stay with a petrol engine. e.g. 4age or similar....even 3.8 commy.Now that would be cool.
Go Hard or Go Home
i need it to drive long distances economically so i wasnt really thinking petrol. but if petrol is easier......i spose ill do that then
how much would the 2.8TD scost to install plus purchase? if you know
rockyman wrote:how much would the 2.8TD scost to install plus purchase? if you know
I really wouldn't know im sorry, but a toyota 2.8 would be easier to find than a Rugger 2.8.
Go Hard or Go Home
best sticking with petrol the way things are going. road tax for deisel has gone up, fuel prices for it are going up and then there is service costs.
also with what ever you change to you are going to find gearing a problem unless you spend big dollars adapting the gearbox/tcase to the new motor. have a look into getting the origonal motor worked and turbo'd etc either that or find a 2ltr or bigger petrol and sp;eend the dollars getting it fitted.
otherwise id leave it how it is maybe run a set of 30'' tyres so that on the open road it revs less and still has a bit of grunt for the hills. i wont run less than 31s on mine but i need the clearance and i pay for clearnce with the loss of power on the hills, if you do this remember get your speedo recalibrated i didnt and it cost me $180 and 35 demerits thought i was doin 110 so new i was in the shit when the cop flashed his lights at me i got done for doing 124
cameronmaxwell@xtra.co.nz
0274202727
0274202727
will 30s fit on a stock rocky? with no mods?
30's should fit may rub a little in the front end though. 31's rub with the torsion bars wound up 65mm but only on the top of the gaurd. just ask if the tyre shop could fit a set up for you to see if they will clear on the agreement that if they fit you'll buy them.
0274202727
0274202727
