1992 Escudo diff preload settings please??
For all Suzuki related topics
Weemsy
Post by Weemsy »
im after the correct preload setting for the front and rear diffs in a 92 escudo.
they are 5.12.
i wish i hadnt pulled them apart cuz they were all fine inside, but if i hadnt they would have spat bits out no doubt. :roll:
cant seem to get a specific setting off anyone.
spanky
Re: 1992 Escudo diff preload settings please??
Post by spanky »
on all of mine i have just guessed and they have never failed cause of what i did,i put them together with a fraction of play and held my tongue right, so i am pretty much useless to you, need to look at a hayes or gregorys type manual,
vaughan
Weemsy
Post by Weemsy »
yeah, normally the tongue out method works for me but i thought i would ask as these didnt seem to have play in them, thats why i asked about preload.
haynes and whatever the other manual is that i have doesnt say about stripping axles, just removing them and giving them to someone who knows what they are doing :lol: :lol:
suzuki main agent 'cant find the details on his computer' and couldnt be arsed to look in the books or on the microfishe. :roll:
Heath
Post by Heath »
Try outerlimits suzuki section
http://carl.outerlimits4x4.com/forum7.p ... 20b944de19
Look in the bible stuff first or you will get flamed (they seem to like doing that) rather than just tell you where to look.
Had a quick look in the vitara bible and couldnt find anything. I'll post for you if you like.
Heath
Weemsy
Post by Weemsy »
cheers heath,
i would appreciate that if you dont mind.
weemsy
lneil
Post by lneil »
Hi Weemsy, I'll duck across to the workshop later today and go through the factory service manuals, see what I can find.
Leigh
Weemsy
Post by Weemsy »
cheers lads.
i can get the good diffs in then!
Heath
Post by Heath »
From outers
9-17 kg/cm
Dont know if it is right (or even what it means but you will I guess), but its a starting point.
Heath
UBZ
Post by UBZ »
lneil
Post by lneil »
Weemsy, sorry I had no joy today. I only had a couple of minutes over there and couldn't find anything straight away.
If you're still looking next week I'll have another crack and see if I can get some assistance from the senior technicians, who are always happy to help me 'cause they know how useless I am!
Weemsy
Post by Weemsy »
cheers leigh,
dont go out of your way cuz it wont be going in for a few weeks yet anyway, so i will build it up when i get the settings.
ive tried that website UBZ sent me, but i cant get the haynes websites to work or find the setting anywhere else? :roll:
the torque settings for the 4 bolts i found (i think thats what you gave me HEATH) but no preload settings......
i will build it up how i would normally do but i dont know whether it is supposed to be preloaded or have a bit of float in the bearing (according to an american guy on another forum)???
Heath
Post by Heath »
is that loose thingeemabob called backlash?
Maybe I asked for the wrong info on Outers.
cool__bananas
Post by cool__bananas »
do you mean how much slap sorta thing there is in between the crown and pinion? cause the correct setting for that (well what we set up our trials truck diffs at) is so you can just hear and feel a litle click when you twist the pinion, like shit all of a mm gap sorta thing
hope that helps :D
Weemsy
Post by Weemsy »
hi cool bananas.
nah, the pinion backlash isnt the problem,
its the tension on the diff assembly bearings im after, the round plates with the holes in with the lock tab that loads the (spool?) bearings.
it might not be too important and they might just be set with the old 'tweak-it-up-and-back-off-quarter-turn' method??
i dont want the bearings whining so i thought i would find out what everyone else does??
i got told they are preloaded A LOT but it seemed a bit over the top so i thought i would ask the people who actually work on these things (you guys :D ) as the settings ive been given seems B.S.
weemsy
cool__bananas
i just tighten it untill it feels good, i havnt blown any bearings yet.... :D
lneil
Post by lneil »
Hi Weemsy
I've just photocopied the whole diff' section of the Suzuki factory service manual (23 pages) so should be able to find just about any info you want.
Side gear thrust play: 0.005 - 0.014 in. (0.12 - 0.37 mm)
Pinion bearing preload: 9.0 - 17.0 kg-cm (7.8 - 14.7 lb-in)
Bevel gear backlash: 0.005 - 0.007 in (0.13 - 0.18 mm)
Tightening torque for diff' carrier bolts: 13.5 - 20 lb-ft (18 - 28 Nm)
Hope this helps. Any other info you need, give me a call.
Leigh
Weemsy
Post by Weemsy »
cheers leigh, thanks for that.
heath was spot on then :oops: sorry heath, i should have listened to you!!!
i will crack on now.
cheers :D :D
Heath
Post by Heath »
Weemsy wrote:cheers leigh, thanks for that.
cheers :D :D
I may have to use that as my signature. Problem is it wont always be correct.
Return to “Suzuki”
