1989 Bighorn, What's the Deal?
Posted: Sat Jul 12, 2008 6:54 pm
by muddy_munke
Hi all,
With my Hilux still in bits, I need a vehicle to get up to the ski field and to work. Currently have a 2wd Ute I'm trying to sell.
Anyway, I don't really know anything about the Bighorns, But I've found one I quite like the look of.
It's the 2.8 Intercooled Diesel.
I'm just wondering if anyone had any gossip and things i should look out for etc.
Cheers for the advice in advance,
Daniel
Re: 1989 Bighorn, What's the Deal?
Posted: Sat Jul 12, 2008 10:43 pm
by mudgripz
Very good truck if you can get one that has been properly serviced. Had a couple and the 2.8T is the model to get. Super diesel - know of one that has done over 1,000,000ks. Also quite strongly built - and 2.8 is stronger than later 3.1s in cvs etc. Had great run with my first one for about 120,000ks and hundreds of 4wd tracks, and now building another one up for offroading/hunting etc. Find them very easy to develop, and tune to good hp. Front and rear lockers available etc.
All round an excellent 4x4 though harder now to get a good low mileage (under 200k) one as people tend to hang onto them. Make sure you do your oil changes every 5k. Set them correctly with adapted suspension for greater articulation, good lift (not high arc springlift or too much shackle/torsion bar wind up) , power tune, lockers or tight lsd etc, and you have a very capable 4wd. Ex power to weight ratio and tough as nails.
Posted: Sat Jul 12, 2008 11:44 pm
by Weemsy
sorry for jumping in on your thread muddy monke
but i was after similar info...
what are the 2.8 diesel mu's like?? i read about the engines being good (i assume they are the same as the 'horn) but what about running gear, suspension etc and rust on bodies and usual things breaking??? also, im after an auto. are the autoboxes any good??
info appreciated.
weemsy
Posted: Sun Jul 13, 2008 10:31 am
by mercutio
Weemsy wrote:sorry for jumping in on your thread muddy monke
info appreciated.
weemsy
have you ever had a look under a mu i have and i couldn't get over how low the transfer case was
Posted: Sun Jul 13, 2008 2:00 pm
by mudgripz
2.8 mu the best one - has same running gear as the 87-92 bighorn which is very sturdy. The auto in that model is a good one - seems to give no trouble in friends trucks. Re transfer case height, this is substantially improved with a set of 33s and no longer a problem offroad.
Posted: Sun Jul 13, 2008 6:17 pm
by Weemsy
how much work to get 33's on? does it need a lift or anything, and how much of a job to body/suspension lift them?
do certain models have factory lockers etc or should i look for particular mods??
sorry for all the questions
Posted: Sun Jul 13, 2008 10:26 pm
by dazza85
I have one and Its great ... 2.8 turbo diesel manual, I have added the inter-cooler.
A must do is replace the heater hoses including the ones to the oil cooler, my one got cooked before I got it because one behind the block split and the steam went down the trans tunnel so no0thing was noticed until too late.
The hose to the oil cooler went on my friends one at the start of a trip ... Steam every where when we stopped to engage hubs, air down tyers etc. We bypassed the whole lot and was away in 1/2 an hour. It took 2 hours to replace the hose when he got home.
Some came out with a limited slip dif in the rear. I have not heard of any coming out with a factory locker but they are available as an aftermarket unit.
I hav tiped it on it's side and did very little damage. Have not lifted it yet But from what I have read there is only 8 spacers required and the cables and brakes etc are long enough. The steering somtimes needs to be swaped with one from another model to get enough length.
As to whether you can fit 33's I am waiting to see ... haven't got the money yet.
Posted: Mon Jul 14, 2008 1:18 pm
by mudgripz
If you want complete data on running/developing isuzus - google clubisuzu.com. Excellent website for owners covering all maintenance and upgrade issues - mostly nz and aus. Mus, bighorns, 2.8s, 3.1s - the lot.
Good trucks to lift. My newest isuzu project is a lwb 88 2.8 and we've just done a 2" bodylift (12 x 50m spacers), which needed radiator lowered 25m and gearstick hole enlarged to accomodate full stick movement. I think from memory 35m body lift you will get away without these alterations. I did the bigger 50m bodylift to avoid winding up torsion bars too much - this can put alot of angle on cvs and limit front travel between bump stops. Really important to avoid heavy duty high arc stiff rear spring lifts as they can totally kill articulation if you use wrong springs.
After body lift I did 25m (rear) and about 50m (front) suspension lift - a bit more at front to level truck. I used 40+mm extended shackles on rear, with some torsion bar wind up plus quick release sway bars setup on front. The extended shackles and swaybar releases give much improved articulation. My last swb bighorn 88 had I think 612 ramp index - 5th of 25 club trucks on a ramp test night - was ahead of a number of cruisers/hiluxs etc. With above lifts my new truck runs 33s with no rubbing problems, no transfer case problems. About 520m to bottom of sills - and overall height increase of 5-6" after 33s fitted. Could esasily handle bigger tyres. Will see if I can post some pics of work so far.
Only 60% developed yet but looking at possible front and rear lockers. For most 2.8 isuzus you can now get front and rear auto Lokkas from aus - which are great - had one in front of last isuzu with tight lsd in rear. Can also get air arbs, and soon could be chinese copy air lockers for front and rear - a good range. The chinese air locker will be getting a good club workout and test soon.
Dazza - you're dead right about checking hoses - also had a heater hose burst once and drove home with big cutout diversion. Simple enough to check them all and change the crunchy ones - esp the little ones behind the block...aaargh - should be done every 100k or so I guess. I didn't use genuine isuzu hoses but got whatever fitted from ripco etc and they worked great.
Posted: Mon Jul 14, 2008 5:13 pm
by dazza85
How did you get on with the steering shaft ? was it long enough
Yes please
That is what I did as well ... There was only one that I had to get the correct hose for because it is a really odd shape.
Posted: Tue Jul 15, 2008 12:13 pm
by muddy_munke
Thanks guys for the Feedback, sounds like they're a good truck.
Cheers Daniel
Posted: Sun Jul 20, 2008 6:40 pm
by mudgripz
Posted: Fri Sep 03, 2010 6:54 pm
by BigSkellsy
Hea Mudgripz, That is one sweet Trooper!
Posted: Sun Sep 12, 2010 8:46 pm
by octanepwr
Hey mudgripz, im looking at doing some work on my bighorn, same model.
With the 50mm body lift did you have to extend the steering shaft?
Also instead of dropping the radiator can you just remove the fan shroud and fit some longer hoses?
Keen to here some details on your custom rear shackles too, I hear they need to be 200mm to get a 50mm lift, where did you get them made up, what did you do for the bushes etc
What offset rims do you have on it btw?
Thanks
Posted: Tue Sep 28, 2010 10:15 pm
by Weasel
Enjoyed my Bighorn, was my first 4wd. Rolled out of car yard at 4pm, and by 8pm had gone for cruise out to Lake Ferry with bro in his Bighorn and got stuck on beach! Call in mate with his 4wd, went and picked up other bro's 4wd, returned with both plus Turfor and got it out at 1:30am
Nothing like a 4wding initiation...
Just threw some pics into a Photobucket thing from Akatarawa's if you're interested:
http://s1191.photobucket.com/albums/z47 ... 20Archive/
Posted: Thu Nov 04, 2010 8:01 pm
by mudgripz
Hello Octanepwr
Yes good truck. With 50m body lift you do not have to play with steering shaft, but you do have to alter gear slot or kink stick.
The radiator does need to be dropped - from memory but not a big job.
Made our own shackles out of 10m thick plate, and you need to add 100m extra to get about 50m height increase. Runs same bushes but we drilled holes into centre of shackle bolts through the head, then a hole into this from mid and side of bolt - then fitted grease nipple into end hole in bolt head so now shackles/bushes greaseable.
Can't remember offset but will have a look. Truck with 33s needed certification.
Very good mods - give good height, improve articulation and truck performs well on and off road.
Posted: Thu Jan 13, 2011 8:20 pm
by Mattman
Nice looking truck. Do you think you would get much rubbage with the 33's without so much body lift?
I am about to do a 3.1TD Bighorn and want to get a good wheel size but minimal body lift and probably about 25mm suspension lift.
Matt.
Posted: Thu Jan 13, 2011 10:23 pm
by octanepwr
Ive done all the mods now, and when flexing 33x12.5s on 15*8s (-24 offset) would rub heaps if didnt have body and suspension lift. Maybe if you dont like the idea of a body lift stick with 32s and just do a 40-50mm suspension lift. 33x10.5s might fit into the guards better but i think will still rub on the corners of the guards. Maybe you would get away with a smaller lift. However brands that do 10.5s seem to be a lot more pricey (bfg only one ive seen) unless you want silverstones which are a bit extreme for the road. In the unlikely event you are not going to use it offroad you would probably be fine with 33s and just a 40-50mm lift. I have hankook 33s which seem true 33s, maxxis mudder 33s only measure about 32
Posted: Thu Jan 13, 2011 10:57 pm
by Mattman
Not sure if the 3.1's have more wheel arch room. Interesting artcile with this guy running a 285 which is about the same as a 33.
http://www.expeditionswest.com/equipmen ... nsion.htmlThink I will try suspension first as it will increase travel significantly by the looks.
Matt.
Posted: Fri Jan 14, 2011 7:54 am
by dave gone jeepy
thou I don't have one, I worked in a 4x4 yard for a couple of years, and drove a the mu and big horn, fantastic trucks in swb sold in aussie as the holden monteray, from memory Isuze where / are the biggest manafacturer of industrial diesel engines.
we had a few issues with the later engine the 3.0 but a great truck to play with.
the guys that came in and did our compression leakdown tests loved them, reliable as.
Posted: Fri Jan 14, 2011 2:20 pm
by mud_slinger
why do you not want to do a body lift? not only does it reduce rubbage it also makes it easier to get to parts of the truck like the back of the alternator and bellhousing and starter motor bolts.
with doing a suspension lift you will get more suspension travel, but being that the front is ifs it wont flex as much but the rear certainly will. you may get away with a 25mm body lift but wont know for sure until you actually do it.
with doing a 50mm body and suspension lift i can fit 34's under my mu and not get rubbing at all.
Posted: Fri Jan 14, 2011 7:06 pm
by Mattman
No need to lift the body unless I have to. Doesn't increase clearance or travel and just raises the cog.
Think I will try a 50mm suspension lift and some small 33's and see where I end up.
Matt.
Posted: Fri Jan 14, 2011 9:25 pm
by octanepwr
Bare in mind im running a large negative offset, that guy in the link has very positive offset (like standard rims) to keep them tucked inside the guards. His tyres also wont be 12.5 inches wide
The larger offset and wide 33s have helped my truck handle just as well if not better than it did as standard on 205s. I also have removed the sway bar and will never be putting it back in (WOF man might bitch so ill put it in just for wof then take it out again as the handling difference is neglible)
It wouldnt surprise me if the 2.8 had more wheel arch room
And yep body lift makes a lot of things easier to access, also increases airflow around engine etc
