As above, PM me if you have 1 for sale.
Cheers.
Solid Axle Hilux Front Driveshaft Wanted
Re: Solid Axle Hilux Front Driveshaft Wanted
I can make you one
I do have some square ones but they wont pass them for a wof but you will never break them
If you are not in need of massive flex, an IFS one will work as well.
Even if you do use IFS front, you can clearance these carden joints by pulling them apart and grinding off the stops.
Yea i realise i can use an IFS one but would prefer to get a solid axle one if i can, down the track i wanna put a long slip yoke in.
If it wasn't a daily driver i would use a square one
whats the problem? you dont use 4wd onroad??
I would doubt i'd get a cert and wofs with a square front driveshaft. As far as im aware they're not road legal.
Last wof i went for i didn't have a front d/s in and i was failed.
- hilux_dave
- Winch master
i didnt even have a front drive shaft when i got my cert and i got a wof with a square drive shaft 6 months later.
hmm thats interesting was thinking i might get a square 1 and if i get failed on a wof chuck the ifs 1 in, makes for a cheaper longslip d/s
if it was full time 4wd you wouldnt get a wof. I had a square one in and got a warrent, something about it being a secondary drive shaft
philux wrote:if it was full time 4wd you wouldnt get a wof. I had a square one in and got a warrent, something about it being a secondary drive shaft
yea it does make sense, since it wont have any effect on the road. Might have a talk to the cert man and see what he says.
