gq front auto hubs
Posted: Thu Jul 17, 2008 10:41 pm
by safaripete
me thinks they are shagged
the right hand side is getting qite hot to toch and the left hand side is stone cold im guessing this isnt normal?
good excuse to by manuel hubs eh?
Re: gq front auto hubs
Posted: Fri Jul 18, 2008 9:43 am
by gary_in_nz
you havent recently done your brakes?? if they are rubbing slightly they will generate some heat through to the hub, but yeah get manual ones any way, then you know your in 4x4
Posted: Fri Jul 18, 2008 10:58 am
by contour
For Superwinch Free Wheeling Hubs what sort of price are they also do they fit straight in ie no need for spacer??
Posted: Fri Jul 18, 2008 11:03 am
by tgaguy1
contour wrote:For Superwinch Free Wheeling Hubs what sort of price are they also do they fit straight in ie no need for spacer??
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Nissan/Other/auction-166269025.htmEverthing you need to fit them comes in the box. You will not have any problems with superwinch hubs.
P.S. These are not mine. I am just a trademe junkie.
Posted: Fri Jul 18, 2008 11:06 am
by contour
is that a good price
Posted: Fri Jul 18, 2008 11:07 am
by safaripete
yeah they seem to "come on" while drivin down tha road so i stop and they clunk out and im away again
yeah i have tha superwinch hubs on watchlist
(minisprint25p)
Posted: Fri Jul 18, 2008 11:10 am
by safaripete
haha well done cotour
just checked trademe
Posted: Fri Jul 18, 2008 11:17 am
by contour
haha thanks yea my hubs were doing the same as you i found driving in 4wd stoped it
Posted: Fri Jul 18, 2008 4:37 pm
by darinz
Just be aware that the Superwinch and all other aftermarket freewheel hubs are ALOT weaker than factory. The factory auto/manuals can be converted to manual witha small mod.
I use whatever I can get cheap, ie at present I have a Superwinch and a AVM hub, as I use them as fuses. Much quicker to replace hub than CV, and I go through a few hubs!!
The other thing is if you have the auto/manuals then they can be fixed. A lot of the problems with them are due to them being greased or dirty. They should be oiled with engine oil only otherwise they will do funny things like engage when in 2wd.
Posted: Fri Jul 18, 2008 4:57 pm
by safaripete
darinz wrote:Just be aware that the Superwinch and all other aftermarket freewheel hubs are ALOT weaker than factory. The factory auto/manuals can be converted to manual witha small mod.
so if i take them off spray them with degreaser then oil them they should work again ok?
or am i better off replacing them?
still seems funny that 1 hub is stone cold and the other is very hot to touch
Posted: Fri Jul 18, 2008 5:33 pm
by nuts
ive only ever had probs with my auto hubs wen they got mud buildup so i clean them and away i go again but wen serious offroading always lock them in saves wear and tear on them
Posted: Fri Jul 18, 2008 6:00 pm
by safaripete
nuts wrote:ive only ever had probs with my auto hubs wen they got mud buildup so i clean them and away i go again but wen serious offroading always lock them in saves wear and tear on them
another dumb question lol
how do i "lock" the auto hubs?
Posted: Fri Jul 18, 2008 6:09 pm
by nuts
21 mm hex head in middle of hubs ,,, turn til they lock , then wen ya finnished with 4x4 turn them oposite way to auto the same as usual to release
Posted: Fri Jul 18, 2008 6:25 pm
by 4WDbits
There are 3 (maybe 4) different factory hubs that came out on the GQ, all are generally accepted to be stronger than many after market brands, some are stronger than others. Check out the hubs the Aussies use in competition. Like Darin says hubs are useful as an easily replaceable fuse. Some of the winch challenge guys have decided to stop replacing hubs (and loosing the $ that cost) and have toughened the CVs and axles and now run the stronger factory hubs. No breakages to date even with front lockers in regular use.
Posted: Sat Jul 19, 2008 7:26 pm
by safaripete
well not a good story now
took my auto hubs off and jacked the truck up to find the wheel bearing farking loose.
so either i didnt it up correctly or what im not sure.
and now the ring that goes over tha splines is abit shagged will get a pic up soon just wanting to know if i get manuel hubs will i need this or not? if i do then does anyone have anything lying around the place?
Posted: Mon Jul 21, 2008 8:47 pm
by darinz
="4WDbits Some of the winch challenge guys have decided to stop replacing hubs (and loosing the $ that cost) and have toughened the CVs and axles and now run the stronger factory hubs. No breakages to date even with front lockers in regular use.
Do you know someone that can supply these flash CV's ????????????????????????
Posted: Tue Jul 22, 2008 11:51 am
by 4WDbits
darinz wrote:="4WDbits Some of the winch challenge guys have decided to stop replacing hubs (and loosing the $ that cost) and have toughened the CVs and axles and now run the stronger factory hubs. No breakages to date even with front lockers in regular use.
As a matter of fact I do. I could tell you to check out my web site where they are cheaper than getting them from Australia, but the forum police might spank my keyboard for advertising on the forum.
Posted: Tue Jul 22, 2008 1:27 pm
by monstr
Re the Chrome Molley CVs and Axels,Weve been running them for awhile now in our comp truck theyve now done a couple of winch challenges and a few grade 5+ runs and were very happy with them i can almost guarantee if we had been using any other set up we would of broken at least one or two CVs ,I priced getting them direct from Cal offroad in Aussie but Warren at 4wdbits beat their price by several $100 and i didnt have to wait 2 weeks for shipping ...Steve
Posted: Tue Jul 22, 2008 8:13 pm
by Terry
I've probably got one out in the rain and cold (woodshed) if you haven't got anything yet - PM me if you need one and I'll go have a look...
Posted: Tue Jul 22, 2008 8:25 pm
by Taz
darinz wrote:The other thing is if you have the auto/manuals then they can be fixed. A lot of the problems with them are due to them being greased or dirty. They should be oiled with engine oil only otherwise they will do funny things like engage when in 2wd.
My drivers side had a bit of a waa last week so pulled it off on Sunday and degreased then oiled it like suggested. Seems to be going all good in auto mode now. Cheers for the tip. Just need to find some more time during good weather to do the passenger side now.
Also are the hubs numbered for left and right?
Posted: Wed Jul 23, 2008 12:19 pm
by darinz
4WDbits wrote:darinz wrote:="4WDbits Some of the winch challenge guys have decided to stop replacing hubs (and loosing the $ that cost) and have toughened the CVs and axles and now run the stronger factory hubs. No breakages to date even with front lockers in regular use.
And the last thing you want is a spanking!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Also left and right are the same.
Posted: Wed Jul 23, 2008 7:34 pm
by Taz
darinz wrote:4WDbits][quote="darinz wrote:="4WDbits Some of the winch challenge guys have decided to stop replacing hubs (and loosing the $ that cost) and have toughened the CVs and axles and now run the stronger factory hubs. No breakages to date even with front lockers in regular use.
[/quote]
Good to know. I couldn't tell the difference between them but had read somewhere that there was a left and a right. Cheers.
Posted: Thu Mar 19, 2009 6:08 pm
by flyingbrick
darinz wrote:And the last thing you want is a spanking!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Speak for yourself
Posted: Thu Mar 19, 2009 9:00 pm
by coxsy
safari peter all the brass bits belong to the autos , if you fit manuals lose those bits but not the circlip, it moves to the outer grove on ya axle
Posted: Thu Mar 19, 2009 9:32 pm
by safaripete
coxsy wrote:safari peter all the brass bits belong to the autos , if you fit manuals lose those bits but not the circlip, it moves to the outer grove on ya axle
yeah after this thread i fitted the manuel hubs and havent looked back
Posted: Fri Mar 20, 2009 4:15 pm
by gary_in_nz
i do miss the auto ones on my safari. i liked watching the other club guys get out in the rain and engage their hubs hahahaha but you just cant rely on the autos. it was the first mod i did to mine. put them manual ones on.
Posted: Fri Mar 20, 2009 7:39 pm
by safaripete
gary_in_nz wrote:i do miss the auto ones on my safari. i liked watching the other club guys get out in the rain and engage their hubs hahahaha but you just cant rely on the autos. it was the first mod i did to mine. put them manual ones on.
haha yeah 1st time i had them on i was at work an went to cross the drain and got stuck because of no auto hubs
