help with holden 202 into hilux
Posted: Fri Jul 18, 2008 7:18 pm
by turoa
I bought a conversion kit to put my injected 202 into my hilux (bellhousing, clutch, flywheel and fork) but there was no spigot bearing included
so.... what kind of spigot bearing do I need to use? I also have a toyota 5 speed in my ute (one tonner) but Im not pulling it apart to find out what kind of spigot bearing to use
so can anyone tell me what I need?
The hilux is the 3rd vehicle of mine that this motor is going into, its got a bit of sentimental value
Re: help with holden 202 into hilux
Posted: Fri Jul 18, 2008 7:25 pm
by Sadam_Husain
You might have to take it to the clutch man to find something to fit
I took all my stuff out to MP Auto parts in UH and the guy there matched up a bearing to fit my carrier and match my pressure plate.
Posted: Fri Jul 18, 2008 7:44 pm
by sig
just measure the spigot shaft and measure the diameter where the bearing needs to sit and get your bearing book out .howie should have a bearing book.you might have to turn up a small adapter bush (being metric to imperial) but shouldn,t be to much of a problem for a person of your resources
.just make sure you use a double sealed bearing (LLU type from memory)
Posted: Fri Jul 18, 2008 7:45 pm
by sig
i,m assuming you mean spigot and not thrust bearing
Posted: Fri Jul 18, 2008 7:50 pm
by taz01
you havnt ripped the motor outa the landie have you?????
Posted: Fri Jul 18, 2008 7:56 pm
by Jerry
I thought the v8 was in the landy?
Posted: Fri Jul 18, 2008 8:00 pm
by taz01
the udder one jerry
Posted: Fri Jul 18, 2008 8:06 pm
by Jerry
Posted: Fri Jul 18, 2008 9:17 pm
by turoa
sig wrote:i,m assuming you mean spigot and not thrust bearing
yep I mean spigot bearing. I might to to BNT and see if they've got anything tommorow otherwise ill just do all the engine mounts etc this weekend and pull it again to do the bearing.
And yea taz, the motor has been pulled from the landy. I dont want it anymore and its taking up room so its getting sold off into little bits
Posted: Fri Jul 18, 2008 9:22 pm
by taz01
and all this going into black beast right???
Posted: Fri Jul 18, 2008 9:30 pm
by callum007
spigot bearing..... you dont need one! well it turns out when they put the 202 into my blizzard they didn't think it needed one..
If you find something that fits.. I'd be interested too. Im picking that Blizzard be similar to hilux, only cos you say you can't find one to suit.. BNT was going to get me new clutch and have it modded to fit bearing..
