Repowering Series II
Posted: Thu Sep 15, 2005 7:18 pm
by V8SeriesII
Can anyone help out with alternative engine and gear box transplants for a series landy. Got a 202 in at the moment, want more power and fuel injection. Looked at a VK but getting harder to source and pretty keen at getting a 5 speed box in there too. V8 would be nice. Anyone with experience? Thanks.
Posted: Thu Sep 15, 2005 10:46 pm
by humvee
Prob not quite what you after and unsure of price but this is tempting
http://www.forward-specialties.co.nz/engine.htm
PS Im currently running a nissan LD28 in my series iii
Posted: Fri Sep 16, 2005 5:40 pm
by V8SeriesII
Great thanks for that, dont want a diesal though and more I think the more I would like to replace engine and gearbox in one. What box are you running with that??
Posted: Fri Sep 16, 2005 6:11 pm
by Furgus
The obvious answer will be a Rover V8 with 'box from a wrecked Disco or Rangy. Whatever you do will some fabrication around the firewall & transmission tunnel & of course new mounts - all need certing if it's to be road legal. Of course just about any motor/box combination can be made to fit with enough work - just depends on what you want to take on
Posted: Fri Sep 16, 2005 7:56 pm
by V8SeriesII
Has anyone trialed with other V8's not range rover?
Posted: Fri Sep 16, 2005 8:15 pm
by humvee
with mine Im running the std series 3 box and transfer
Posted: Fri Sep 16, 2005 11:04 pm
by Furgus
Posted: Sat Sep 17, 2005 9:49 am
by V8SeriesII
Yeah I have a couple Vk's already and my red motor has the yella terra head on it so it's not bad already, im thinkin I mite just stick with a VK and have the cam machined. Get EFI and a better motor that way. I would really like to upgrade to a 5 speed box with that setup though? Any sugestions there? Also, I have already put power steering into our other one using a pajero steering column and I think an SJ80 steering arm with holden pump? Any other easier options there second time round? Thanks.
Posted: Sat Mar 18, 2006 9:12 am
by turoa
have you decided what you're doin yet? I run a holden 202 with EFI and it runs very well. Is more reliable than the carby engine that was in it. It is backed up to the landy gearbox and transfer case. It would be nice to have an auto in it if anyone knows of an adaptor kit?
