steel diff housing wanted vitara
Posted: Mon Jul 28, 2008 8:31 pm
by tara13
Anyone know where i could get a steel front diff housing for a vitara . I blew a hole in a alloy one on sunday so took spare one out today only to find crack in same place as first one broke so then had to raid vitara number 3 .Need to give diff a clean and hope it is not cracked as well .So will look to replace with a steel one soon. :shock: :shock: :( :(
Re: steel diff housing wanted vitara
Posted: Mon Jul 28, 2008 8:46 pm
by Weemsy
te puke parts world have some from a grand vitara, i spoke to them today about one for myself and they want $1300.
i think thats for one with your diff internals swapped into it to give the right ratio.
Posted: Mon Jul 28, 2008 8:50 pm
by turoa
its probably cheaper just to put a lux diff in
Posted: Mon Jul 28, 2008 8:54 pm
by madaz068
I have a alloy one going cheap also have other vitara parts going cheap just want parts gone as have sold vitara
Posted: Mon Jul 28, 2008 9:23 pm
by coxsy
was told all aussie ones are steel :D
Posted: Tue Jul 29, 2008 10:23 pm
by lneil
Haven't priced them up, but contact 4WD accessories in CHCH for a price on the calmini anvil housing. This is a purpose built steel front housing that is set up to run two short-side axles, so you don't have to have different lengths.
List is $US630, and Nick can price pretty competitively, the only thing I'm not sure of is whether they will work without a suspension lift. I'd suggest you see if you can find anyone that's tried one here in NZ to see how good they are.
Because every parts seller knows how sought-after the steel housings are they always seem to want $1200 to $1500 just for the housing. They only came out on the V6 manual Grand Vitara and XL7 from what I can gather. That could make the Calmini unit a good option if it will fit your truck.
Posted: Thu Jul 31, 2008 7:28 pm
by tara13
Thanks for options but funds are low so i will have to make do with ally one for now did get a price of 1400 for steel banjo and carrier or 800 for banjo 600 for carrier out of diesel tara te puke parts world .
