Tyer conversion chart
Does anyone know of a conversion chart, I want to know what the size of my 31" tyres are in the other system, ie. like this example 215/75 R 15
Ph 0212078472
Ph 0212078472
- skid
- Tyre Man
Re: Tyer conversion chart
265/75 r15
Go to 4wdbits.co.nz hit tec sec
- skid
- Tyre Man
Browndog wrote:Go to 4wdbits.co.nz hit tec sec
hes right
we all forget about that place from time to time
I actually use at work in the tyreshop
http://www.4wdbits.co.nz/ProductsList.a ... election=3
Thanks guys and skidder.
Ph 0212078472
Ph 0212078472
a 240 80 15 is as close as you can get metric in therory if runimg 15s
- skid
- Tyre Man
Imperial LT Tyre Size Calculator Select Wheel/Tyre
Results for your selected Wheel/Tyre 31 / 10.5 R 15
Metric Equivalent 265 / 75 R 15
Rolling Radius 389.25mm
Circumference 2445.73mm
Diameter 778.5mm
as found here............
http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
the 4wdbits one didn't tell me what you really wanted to know
sorry to browndog, but when someone who has no knowledge of tyres posts up a tyre size like 240/80r15, then I have to respond.
If you can even find a tyre in that size, you're doing great.
as qouted the first time and above 265/75r15 is what you're after
now can I ask why you wanted to know this info, please.
Maybe in height but its a skinny wee tyre. And I doubt available.
As Skiddy said, 265/75/15 or the 265/70/16 Firehawks I run as road tyres
Saw some chains but are for these specks.
FIT THE FOLLOWING 215/75 R 15,205R 14,215/70 R 15,20575 R 15, 205/70 R 16
As a side note I have 31" Saveros, love to get some more in 33" but they are not available now.
Ph 0212078472
Ph 0212078472
- skid
- Tyre Man
those chains wont fit
those chains wont fit![]()
I realise that now, thats why I wanted to know what the measurements were/was/are.
Ph 0212078472
Ph 0212078472
skid wrote:those chains wont fit![]()
No, but they are near perfect for a standard 'zuk jimny or 3Dr G/Virara if anyone's looking for some chains.
Mind you, there don't seem to be too many standard 'zuks on here!!
