hi all
when i put my foot on the brake the front wheels shuder. could it be the rotors? i have a 1991 yn106 hilux
Hilux brake prob
Re: Hilux brake prob
yes, have the rotors machined or replaced and wack some new pads in
- Steve_t647
Most likley the rotors if you pull a wheel off and manualy turn the rotor you may be able to see it (looking end on or at the caliper distance fron the disk) if it is a lot of movement machining may make them too thin depends how hot they were when the were run into a puddle in all this rain.
Could also be wheel bearings or a sticky piston in the brake caliper. Easy (and free) to check these things first
