im after trans spacers for my 88 SWB safari with 4" lift
dose anyone have any for sale or were to get them a a good price.
cheers kyle
wanted trans spacers
- gary_in_nz
Re: wanted trans spacers
check out this thread> if you can use a drill and a grinder your away!!
viewtopic.php?f=25&t=9319&st=0&sk=t&sd=a&hilit=gearbox+spacers&start=15
There is some for sale on Tm at the moment OR you could make some out of 12mm lexan like i have..been in there for 2yrs and are sweet.Local plastic seller will have a bin full of offcuts for nix and its easy to work with.
- gary_in_nz
hey mud bum, just looking at your avatar> what size tyres do you run?? and how much lift you have??
i put 10mm spacers in mine and has no more vibrations
I run 33's with a lwb 2in lift at the rear with 30mm coil spacers and swb 2in at the front,the vib is only just there at 85km to 90km and not noticable to anyone else in the vehicle.Also have dropped both swaybars and this seems to allow the girl to sit a bit better with suprisingly good on road handling (for a lifted Saf)
thanks guys mite go for 20mm spacers cheers
