The front wheel traveled up the ramp to a verticle distance of between 325 and 350 mm (13 to 14 inches) before the other wheel just started to lift off.
the pajero suspension is standard in the rear, the front has the sway bar removed and lower bumpstops trimmed.
With the front stops trimed it should have about 6 inches of travel, so I guess the back end was flexing enough to deliver the other 7 inches.
How do these numbers compare, they seem to be relatively pathetic
Would be interested to find out what other standard and modified suspension guys get .
