Alternator
Posted: Mon Aug 18, 2008 3:05 pm
by Henry
Hi
Where do I look for a second hand Alternator for a 93 Safari Turbo 4.2 l diesel. Auto. 24Volts.
The shaft spline the vacum pump sits on is stuffed..
Thanks
Re: Alternator
Posted: Mon Aug 18, 2008 3:15 pm
by valiant87
if ur in Christchurch try Falsegrave Auto Spares or Partsworld 0800 355655 <---nation wide
Re: Alternator
Posted: Mon Aug 18, 2008 3:23 pm
by Henry
Thanks Will try them.
Re: Alternator
Posted: Mon Aug 18, 2008 3:32 pm
by albundy
Henry, I have just gone through all this bullshit with the crappy hiatchi alternators for safaris. They won't be cheap second hand, nor will it be reliable if you get it rebuilt. Buy a new one if you really want to stick with the current set up. I went for one with a bigger amperage off of a nissan truck, FD I think. If you give Kaiapoi repowers a call, talk with Nathan, they have one on the bench, tell them Al sent you out. I even looked at grafting a toyota nippodenso one on as the are heaps more reliable the hiatichi. None of them match or can be bastardised to fit, shame really, so I went for the next best option, bigger amps.
Al
Re: Alternator
Posted: Wed Aug 20, 2008 11:31 am
by doby
Hi, can any one tell me wich of the two oil lines on the back of the alternator is the feed & drain? Is the small one the feed and the larger one the drain?
Cheers.
Re: Alternator
Posted: Wed Aug 20, 2008 1:21 pm
by Shane
doby wrote:Hi, can any one tell me wich of the two oil lines on the back of the alternator is the feed & drain? Is the small one the feed and the larger one the drain?
Cheers.
Correct: small hose feed, Large hose drain.
Why do you need to Know?
Shane
