hand brake light - help please
For all Nissan related topics
tracta
Post by tracta »
need some help please
on the weekend I replaced the front brake pads. this morning I noticed that when I put my foot on the brake pedal it lights up the hand brake light. I did spill some brake fluid when I was changing the pads, is it possible that this has got into the elctrics somehow ? or is it likely to be the elctrics behind the dash - just seems to be odd that it only happened after I did the pads.
cheers for your thoughts.
NJV6
Re: hand brake light - help please
Post by NJV6 »
Did you top it up after you spilled some...
tracta
Post by tracta »
nah it was still full ( quite a bit was forced back up )
albundy
Rolly Polly
Post by albundy »
What sort of vehicle are we talking about.
albundy
Rolly Polly
Post by albundy »
Just had a thought. It if it is safari and there are vaccum issues it will show by lighting up the handbrake light when depressed. The brakes should also feel heavier to push. Is this happening? Or it may need re-bleeding.
Al
tracta
Post by tracta »
haha good point, its a 91 nissan terrano.
albundy
Rolly Polly
Post by albundy »
Diesel or pertol. petrols have no vac assist and that year didn't have any sort of ABS, I think, check with the nissan workshop in town. The diesels do have a vac pump but not sure if they assist brakes or not. Flick kiwipete a pm and ask him if they have vac assist brakes, if so go back to my last post about the fluid.
Al
tracta
Post by tracta »
will do, cheers.
Re-check the brake fluid level coz there often a low fluid level warning as well as a handbrake light
kiwipete
Post by kiwipete »
albundy wrote:Diesel or pertol. petrols have no vac assist and that year didn't have any sort of ABS, I think, check with the nissan workshop in town. The diesels do have a vac pump but not sure if they assist brakes or not. Flick kiwipete a pm and ask him if they have vac assist brakes, if so go back to my last post about the fluid.
Al
You are right on the money Al, they do indeed have vac assisted brakes.
Ph 0212078472
meatc
Post by meatc »
Sadam_Husain wrote:Re-check the brake fluid level coz there often a low fluid level warning as well as a handbrake light
Would be my vote.
Where did you spill the oil from? If it was from the resiviour then the level is prob low when you force the fluid down the lines. It all will have settled back a bit once installed and the pistons push back out a bit.
If you released the bleed valve to get the pistons back (shouldn't have to) they may need a rebleed
doby
Post by doby »
Think I might have a vaccume issus with my safari brakes. Have brand new pads, discs & just bleed them (Safari TD42 turbo) When its at idel & you put your foor on the brakes the (!) light comes on :? . Where is the first place I should look?
Cheers.
albundy
Rolly Polly
Post by albundy »
Try checking all your vacuum lines from the vacuum pump on the back of the alternator back to your brake master cylinder.
Al
Heath
Post by Heath »
My father in laws Isuzu Wizard has an issue with the handbrake light staying on all the time. He has checked the obvious (switches,fluid levels) but what else causes this light to stay on?
Its an auto if that makes a difference.
Heath
sibainmud
Post by sibainmud »
All of the above is correct. The light has 3 ways of being activated. First step, disconnect the two wire plug off the master cylinder tank, see if that stops the light. if not there is a vacuum switch near the air filter that is connected to the small tube coming off the vacuum pump on the back of the alternator, disconnect that next, see if that works. the only other switch in the system is the hand brake micro switch. the hand brake and the vacuum switch are switched to ground and the reservoir switch has two wires, one coloured and the other black which is the ground supply to the micro switch at the master cylinder.
These steps will tell you which one is at fault.
If it is the reservoir, try pushing the float to the bottom and let it float again. Some times these do stick in the closed position.
But it sounds like the vacuum switch or the booster diaphragm has a leak, so when you put your foot on the brake it looses vacuum and causes the light to come on.
I hope this helps.
playingInTheDitch
Post by playingInTheDitch »
hey sibainmud
that sounds like it might help with my handbrake light being on all the time. suspect its the handbrake microswitch but it wouldnt hurt to check the rest
charo249
Post by charo249 »
The above is correct light activates when handbrake is on, when fluid level is low or when vacuum pump isn't working. If you aren't that mechanical, remove the alternator (vacuum pump is on rear of alternator usually) and take to an auto sparky to check out, chances are if the vacuum pump is struggling the alternator will also be on its way out, especially if you drive in muddy/dusty conditions.
canadianwood
Newbie
Newbie
Post by canadianwood »
tracta wrote:need some help please
Hi just wondering if you fixed your issue. My 1995 mistral is having the same issue> did you have a vacuum leak or was it something else?
Best wishes
Canadianwood
timmay556
Post by timmay556 »
sibainmud wrote:All of the above is correct. The light has 3 ways of being activated. First step, disconnect the two wire plug off the master cylinder tank, see if that stops the light. if not there is a vacuum switch near the air filter that is connected to the small tube coming off the vacuum pump on the back of the alternator, disconnect that next, see if that works. the only other switch in the system is the hand brake micro switch. the hand brake and the vacuum switch are switched to ground and the reservoir switch has two wires, one coloured and the other black which is the ground supply to the micro switch at the master cylinder.
I hope this helps.
This fixed my issue. The hose from the alt to the left front guard had fallen off. Made my clutch pedal heavy also. Cheers mate.
