Wheel spacers
- Beer_Cruiser
Wheel spacers
I just got my new Pittbulls home put them on the 40 and they are rubbing on the back springs
So Im thinking I need some spacers
Has any one in the wellington area got some I can borrow for the weekend till I can buy some
Or know of some for sale.I was hoping to have Pittbulls on for a club trip this weekend
Thanks Malcolm
Thanks Malcolm
Re: Wheel spacers
how wide do you need
- Beer_Cruiser
Re: Wheel spacers
sig wrote:how wide do you need
Am not realy sure
I think Im going to need about 25mm. Does that sound about right?
- cool__bananas
Re: Wheel spacers
what trip is that? the 10hr track on saturday?
Re: Wheel spacers
holy hell thats a wide spacer ,put a sixty rear housing in that will get you 30mm a side .and probably not much dearer than spacers
- Beer_Cruiser
Re: Wheel spacers
Jerry wrote:has Rob got any?
Tryed Rob he will have to get some in
Wont be here by tomorrow
- cool__bananas
Re: Wheel spacers
why dont you just use your other rims atm?
- Beer_Cruiser
Re: Wheel spacers
cool__bananas wrote:what trip is that? the 10hr track on saturday?
Yep will be a good run on new tyers
sig wrote:holy hell thats a wide spacer ,put a sixty rear housing in that will get you 30mm a side .and probably not much dearer than spacers
So how wide should they be
I just want to clear the springs
- Beer_Cruiser
Re: Wheel spacers
cool__bananas wrote:why dont you just use your other rims atm?
Thats a good idea. Think thats what I'll do
Its no wonder they call you the Driving God....
Re: Wheel spacers
Have you changed to 10" rims to fit the new tyres Malcolm?
Re: Wheel spacers
if you fit spacers you will have to get it certified to be road legal would be cheaper to get different rims.
Re: Wheel spacers
in my opinion spacers are a temporary measure.if you are going to keep the pitbulls (you could give them to me
)you would be better off going for a sixty housing , this will give you the extra width with still full stud thread contact .i,ve got a sixty housing (for my next incarnation) you can have and just replace it ,if this helps.probably a bit short notice to put it in but its just gathering dust from sadams motor at the moment (which is almost finished ,yaaaa)
- cool__bananas
Re: Wheel spacers
your rims are still sitting on the floor, yours are the next set to do, but grab them tomorow and chuck them on
and then you can clean them cause i dont like getting dirty hands when working
- Beer_Cruiser
Re: Wheel spacers
Sadam_Husain wrote:Have you changed to 10" rims to fit the new tyres Malcolm?
Yep got a set of 10" rims beadlocked
Thougt I was flash as Mitch till I put them on and had a look
tallsam66 wrote:if you fit spacers you will have to get it certified to be road legal would be cheaper to get different rims.
Is not a road going 40 so no worrys there
Re: Wheel spacers
if you get stuck ,my spare 10.5 inch bead lock rims (which are stripped at the moment ) have lots of offset (stick out the side lots )and you are more than welcome to borrow them .can fit them up tomorrow night if you want
Re: Wheel spacers
cool__bananas wrote:your rims are still sitting on the floor, yours are the next set to do, but grab them tomorow and chuck them onand then you can clean them cause i dont like getting dirty hands when working
Better still Mitch could wag school tomorrow (you'll have to write a note for his teacher Malcolm) and he can beadlock the new rims and change the backspace for you tomorrow at work and if your lucky there will be time for a bit of paint to be sprayed on them before you swap the tyres over tomorrow night
- Beer_Cruiser
Re: Wheel spacers
Do you think if I use my old rims the tyres would clear the springs
Pittbulls are a bit wider than the Kumhos I had on
Re: Wheel spacers
na i dont think they will clear, best off you borrow those rims from sig
- Beer_Cruiser
Re: Wheel spacers
Thanks mate Will give that a try
Re: Wheel spacers
if they are attached to his truck better borrow that as well
(Saves taking the wheels off
- cool__bananas
Re: Wheel spacers
just cut the springs or put nissan suspension on it
- skid
- Tyre Man
Re: Wheel spacers
are they rubbing bad
I got a couple of 5mm spacers here
otherwise will check at work tomorrow for adapters
PM your cell, malcolm
Re: Wheel spacers
i have 50mm spacers you can borrow they bolt on and you bolt the wheels to them
NO one remembers who comes 2nd....!
Re: Wheel spacers
gazza wrote:i have 50mm spacers you can borrow they bolt on and you bolt the wheels to them
if your gonna use spacers theyre the best sort.... ive seen quite a lot of sheared of studs because of those 'slip-on' spacers, and thats only on car wheels, i hate to think how much more force a 33 or 35 inch mudd on a heavy steel rim would have....
the bolt on ones are still bloody hard on bearings though.
Re: Wheel spacers
nstg8a wrote:gazza wrote:i have 50mm spacers you can borrow they bolt on and you bolt the wheels to them
these were running 39 tyres for 2yrs never had any probs with bearings and the wider wheel base made a big differance in the ruts
Re: Wheel spacers
I stopped in at Robs Tyre Shop this afternoon to talk some bullshit and tell some lies and I had a look at Malcolm's new tyres and the ones on Robs Cruiser..... and Fark me those pitball's are wide
Shit they made Malcolm's old 35" kumho's look like little space saver tyres
- skid
- Tyre Man
Re: Wheel spacers
PICS
WE NEED PICS
WE NEED PICS
Re: Wheel spacers
skid wrote:PICS
WE NEED PICS
Mate Pic's dont do them justice.... you've got to go up to Robs and look at them in the flesh to see just how big they are
Re: Wheel spacers
nearly there sadam ,sump is on ,heads and intake to do
then its changover time
