V8 diesels
safaripete
V8 diesels
Post by safaripete »
does anyone know anything about chev V8s?
thinking about either turboing my safari or putting V8 in
was thinking either a 350 or 383
will the gearbox handle the v8 punishment?
anything else some of you could let some light on please would be much appreciated
cool__bananas
Re: V8 diesels
Post by cool__bananas »
put a 400 in it, my dad has a injected 383 and the running gear is sweet as, his one has a larger heavy duty chev clutch to fix that problem as well, but i agree with the weight, those boxes and transfer cases are heavy as
tweake
Re: V8 diesels
Post by tweake »
http://www.patrol4x4.com/forum/ has a fair bit on the diesel chev v8 conversions.
just be carefull with later model GU's tho, seams to be a few problems with chassis cracking.
Bulletproof
Re: V8 diesels
Post by Bulletproof »
safaripete wrote:does anyone know anything about chev V8s?
A friend of mine in Nelson has fitted a Chev V8 to his short wheelbase. He has also fitted the chev auto gearbox as well. He said it is a lot lighter than the nissan gear.
I cant give you more details but if you need to know specific specs. PM me and I will find out as he only works about a kilometer from my house
Richard
Never say die, up man and try
turoa
Pyro Junior
Re: V8 diesels
Post by turoa »
dad put an lt1 and chev auto into his nissan in about 2001 I think. It did about till 06 as a daily drive (on 35's) and 07 as a tow vehicle and offroader until the auto clutch packs gave out. Currently awaiting an ls1 and new auto, but gonna change the diff ratios this time (too high on 3.9's). It went really well (LWB) for a heavy nissan. The new engine and gearbox is 40% lighter than th eoriginal
safaripete
Re: V8 diesels
turoa wrote:dad put an lt1 and chev auto into his nissan in about 2001 I think. It did about till 06 as a daily drive (on 35's) and 07 as a tow vehicle and offroader until the auto clutch packs gave out. Currently awaiting an ls1 and new auto, but gonna change the diff ratios this time (too high on 3.9's). It went really well (LWB) for a heavy nissan. The new engine and gearbox is 40% lighter than th eoriginal
is an lt1 a diesel??
turoa
Pyro Junior
Re: V8 diesels
Post by turoa »
aah are we talking about diesels? no its a petty, i wouldnt go near those smelly old things :wink:
but seriously, have heard the 350 diesel is a very pus engine and the 6.3l is the best one, but may be best to do a bit of reading on that
cool__bananas
Re: V8 diesels
safaripete
Re: V8 diesels
yeah thats what i had heard
im quite keen on keeping my truck diesel but love sound of a V8 :mrgreen:
sig
Jeep Jeep
Re: V8 diesels
Post by sig »
get a 6.5 chev diesel ,6.2 were ratly old things and made bugger all power .i know 2 guys who put 6.2 diesels in and resulted in one being taken out and replaced with a petrol and the other sits in a workshop as an occasional bed !!!!
safaripete
Re: V8 diesels
ok more questions
where would i find a 6.5L?
how much are they worth?
GQTROL
Re: V8 diesels
Post by GQTROL »
Heath Lawson in AU is now running a 6.6L Duramax with Alison 1000 trans (twin pto outputs!!) in his GU ute. 440HP at the wheels in stock form. Running it on 1/4 mile instead of Outback Challenges now, hopes for 11 sec pass once its dialed in. Pretty respectable for a 2.5T truck.
KiwiBacon
Re: V8 diesels
Post by KiwiBacon »
The chev diesels don't seem to be anything to write home about. You'd be better with a TD42 and a turbo.
Here's some light reading.
http://www.4btswaps.com/forum/showthread.php?t=2554
The duramax however. :twisted:
DaveM
Re: V8 diesels
Post by DaveM »
timotheus
Re: V8 diesels
Post by timotheus »
Shane
Re: V8 diesels
Post by Shane »
you are better off getting a good turbo kit for the TD42 which well make a huge difference to how it performs.
The TD42 is a very heavy engine and replacing it with a even heaver one doesn't make scents IMO that only has alittle bit more power.
Shane
worthog
Re: V8 diesels
Post by worthog »
My 1997 Shorty GQ was a factory turbo model and I fitted a propane kit ex USA. However, since I have had the 5.7 litre chev V8 installed (3 years), it goes far better. Still running the GQ gearbox etc with 4.625 diffs and reduction crawlers in the low ratio box to hold it back on steep down hills.
Now theres a great truck all setup ready to rock and roll for you injected V8 complete with Tunercat and Datamaster tuning programs on a laptop to let you twinkle with the tuning.
www.trademe.co.nz/Browse/Listing.aspx?id=171992459
Turoa and cool bananas will vouch for it
2001 Mitsubishi Diamante VRX Sport
swampa
Re: V8 diesels
Post by swampa »
hi, where do you source propane injection from, i have an 80 series with the 24v motor, i want some more grunt for towing, whats the best solution? propane, bigger turbo, intercooler? dont want to change engine
worthog
Re: V8 diesels
Post by worthog »
This is where I purchased my kit from
www.dieselperformanceproducts.com
Another chap Colin Brewer, who use to live in Wellywood also had one on his Nissan GQ, but now he is in Aussie.
swampa
Re: V8 diesels
Post by swampa »
thanks
KiwiBacon
Re: V8 diesels
Post by KiwiBacon »
swampa wrote:hi, where do you source propane injection from, i have an 80 series with the 24v motor, i want some more grunt for towing, whats the best solution? propane, bigger turbo, intercooler? dont want to change engine
Before you spend any money on propane, read this:
http://www.eng-tips.com/faqs.cfm?fid=1147
Intercooler if you don't already have one, then more boost and fuel. Buy yourself both boost and EGT gauges before doing either.
swampa
Re: V8 diesels
Post by swampa »
so the first thing would be to buy a good quality intercooler kit, then boost turbo, sshould the exhaust be done first or later, has 2.1/4 inch as standard, cut the big muffler out today and replaced that with straight pipe
KiwiBacon
Re: V8 diesels
Post by KiwiBacon »
swampa wrote:so the first thing would be to buy a good quality intercooler kit, then boost turbo, sshould the exhaust be done first or later, has 2.1/4 inch as standard, cut the big muffler out today and replaced that with straight pipe
Did the muffler make any difference?
I've got 2 1/4 on my diesel at the moment. I plan to go bigger but I have a lot of projects competing for my time and money.
It makes sense to do the exhaust when you know you're sticking with that turbo. Otherwise you need to remake the dump pipe twice.
worthog
Re: V8 diesels
Post by worthog »
Another point with fitting a propane kit is that if your truck is a trayback, the job is a lot simpler. Mine was not and hence the propane, which was in a barbeque bottle inside the rear of the truck, had to be in a sealed container with a hole down through the floor. I fitted a ply box all glued and screwed together, cut a hole in the bottom and out through the floor of the Nissan. The hole acted as two items, - one for letting the cables coming to the bottle come in and two it let any escaped propane out of the cab, if it leaked. My system was inspected and passed WOF checks. It now been sold and the chap still hasnt fitted it to his Nissan.
When you want extra power, you just flicked on the dash switch and watched propelled into the air!!!!
On a tray back, its alot easier to install cause the barbeque bottle is not inside your cab
safaripete
Re: V8 diesels
cheers for all you info there guys
have decided to keep the td42 and add a turbo from a tractor that i can "get" reasonably cheap from the tractor company we share a building with
will keep you all posted
also where can i find an exhust manifold for turbo? or should i give it a shot and make 1?
tweake
Re: V8 diesels
Post by tweake »
exhaust is almost always the first engine mod that should be done.
swampa
Re: V8 diesels
Post by swampa »
it surprised me how much difference it made, no diff from a standing stsrt but when rolling it made a noticeable change, gonna do an intercooler next week. i see 1 advertised on a site in nz for my car, will give that a go i think and then do a 3 inch exhaust
LOLYF
Re: V8 diesels
Post by LOLYF »
Try this http://www.4wdbits.co.nz/ProductDetails ... uctID=1208
I've been for a trip in the 80 series this is fitted to and it made a noticable difference to power and droped the EGT by between 50 and 100 degrees.
it is now a full water to air and is even better.
swampa
Re: V8 diesels
Post by swampa »
going to get hold of them over the next couple of days, should i wait till the full water to air intercooler comes out, or would i be happy with the air to air one?
LOLYF
Re: V8 diesels
Post by LOLYF »
they have a working prototype of the water to air now so shouldn't be far from production.
in terms of efficiency it would be strait air to air then air to air with a hole in the bonnet and a scoop :o then water to air. it all depends how far you want to go. And how much you want to spend :D
