ARB fitting help
For all Nissan related topics
tpft
ARB fitting help
Post by tpft »
just picked up a s/hand ARB bull/winch bar and rear bar and sides for a safari off trade me.
basically s/hand with a big bag of bolts...good fun!!!!
Anyway rh side bolted up to the rh chassis rail no promblems using origanal captive nuts that were inside rail.
lh side only some of the holes line up, plus they just holes, no nuts on inside of rail, and they don,t go all the way threw??
anyone got a set of instructions for thease or know if perhaps i,m missing a captive nut plate or something that should have come with bar?
95 Safari on brg 33,s/ 4age e class zuk (old faithfull)/ d class rig under construction.
3VILC
Re: ARB fitting help
Post by 3VILC »
Id say you should have a captive nut plate..the old aliarc bar i pulled off mine just had a home made one, bit of rusty plate with the nuts tacked on..my new bar came with a fancy stainless one with a rod welded to it to hold onto it. So you could probably make something up easy enough. Id say your ARB mounts would be similar to my TJM mounts. Should be three holes on the left as well, exact opposite of the right.
RH side has factory captive nuts same as yours..think this is where the factory recovery hook is meant to be.
Your welcome to have a look at mine sometime as your just up the road :)
muskie
Post by muskie »
you are definatly missing the plate with 2 nuts welded on, i bought a new arb bar for my old safari and remember the plate.
Bushrash
Post by Bushrash »
haha you got that front bar and side bars ,,,,lol good buying was keen on those!!!
3VILC
Post by 3VILC »
Re: muskie
my captive plate has 3 nuts..of course the arb mounts could differ to my tjm ones. Mine the outer tabs go inside the chassis rail where the original bumper irons go an have nuts attached and bolt thru the original bumper holes, the inner tabs go on the outside of the chassis rail and bolt thru the 3 holes there, which is where my captive plate is as only the drivers side has the nuts already in the chassis.
Maybe of some help
