Has anyone tryed doing it, Is it much effort?
My neighbour totaled his 1992 surf and as offered me his rather nice bullbar, I think it could be an Arlic? one or sumthing its alloy i no that much, its got the mounts n that for a winch as well.
my question is, how much work will it be to fit it on my 1992 terrano, bearing in mind the only power tool i own is a drill lol cuz im a poor uni student. also roughly how much is a second hand bullbar worth anyway, ie how many boxes of beer shuld even the score
Surf bullbar on a terrano
Scarfies on the piss,
Re: Surf bullbar on a terrano
trust me mate mounting a bullbar to a terrano thats not of a terrano is a major!!...... i modified a patrol one(steel) to fit my terrano, easier with steel to cut and weld to fit.... make sure its the right width etc.....and you probly want to get an engineer to make new brackets to bolt to your chassis rails as the terrano bumper mounts arent that flash
hope this helps
by the way, would you be interested in some lift springs for your terrano?
hope this helps
Armz wrote: also roughly how much is a second hand bullbar worth anyway, ie how many boxes of beer shuld even the score
I'll give you 2 boxes
Best thing is to remove your existing bumper and have a look at how this new one will fit in there and what modifications you will need to do.
The bumper isnt too hard to remove, there are 2 bolts securing each of the 2 bumper irons. Loosen the two top ones and remove the two lower ones and jiggle it off.
Remove the indicators from the bumper first.
I have done a post on here of my winch mounting on the Terrano, (do a search for it), and you will see what I mean about the bumper irons.
Yell out if you need any other suggestions/ideas.
Ph 0212078472
Ph 0212078472
Thanks guys your advice was good - 2 hard basket, il just keep waiting till i find a terrano one, t
Thanks for the offer but ive already got a 2inch lift so shel b right
found it, thinking bot doing something similar. just wondering if you could put a side on photo. im wondering how far it sticks out and if it effects your approch angle?
Ryan wrote:would you be interested in some lift springs for your terrano?
kiwipete wrote: my winch mounting on the Terrano
I will get you some pics tonight. Hang onto that winchbar all the same. I may be interested in it yet.
Ph 0212078472
Ph 0212078472
