Diff Measurements
Posted: Tue Sep 16, 2008 10:26 pm
by 2MEKE
I'm after a few measurments....can someone fill in the blanks
1. WMS to WMS for an 8" cruiser?/prado? rear diff (the ones with an offset diff head)
2. Right WMS to pinion centreline.
Re: Diff Measurements
Posted: Wed Sep 17, 2008 5:47 pm
by Bulletproof
2MEKE wrote:I'm after a few measurments....can someone fill in the blanks
Excuse my ignorance but I don't know what WMS is.
Simply put you do the the adjusting shims up until they are the right preload and then wind them across evenly until the dial gauge says you have 5-7 thou of an inch backlash between the teeth.
After doing the bearings up tight the right preload is 1.5 holes back.
Probably useless info for what you want
Cheers Richard
