From my Lada site:
http://www.ladaniva.co.uk/baxter/resour ... rnList.htmOther Vehicles with the Suzuki/Niva's 5 x 139.7mm (5 on 5.5 inches) PCD.LadaNiva (2121, Hussar, etc) – fitted with 16” x 5” wide, (ET57, ie a High offset)
Wheels: disk stamped, rim size 127J-406 (SJ-16). Tyres: radial-ply 175/80R16 with 315 mm static radius or cross-ply 6.95-16 (175-406) with 322 mm static radius.
Cossack (aka Turist, Toro, etc) OEM rims - 15” by 5.5 or 6, (H offset), vary slightly in different markets.
SuzukiLJ 80, SJ 410, SJ413, Jimny, Samurai, Escudo, Sierra, Caribbean, X-90, Vitaras & some Grand Vitaras – mostly 15 x 6 (L/M offset, -10...15mm)
Sidekick (USDM) ’96 - ’97, 16 x 7 (M offset)
Vitaras & some Grand Vitaras (USDM) ’98 -, 16 x 7 (L offset)
Maruti / Maruti UdyogGypsy mostly 15 x 6 (L/M offset, -10...15mm) (Indian licence built Suzuki SJ)
KiaSportage ’94 on, 15 x 7 (L/M offset, 0...-3mm)
Rocsta
Maybe some Sorentos? 16 x 7s
DaihatsuTaft/Scat: F10, F20, F25, F50, F55, F60, F65
F70/Fourtrack/Rugger/Rocky/Wildcat/Feroza – probably 15’s (offset 0...-3mm)
Dodge 2Ram 1500 4WD
Ramcharger ’79-’83, 15 x 6.5 (all L offset)
Ram Charger ’88 – ‘93
Ram ½ ton truck (2wd and 4 x4) ’94 on, 16 x 7
Ram van ’85-’96, 15 x 7
½ ton truck 4x4 ’79 – ’83, 15 x 6
½ and ¾ ton truck ’84 – ’93, 15 x 7
HoldenDrover (Australian rebadged Sukuki SJ) (L/M offset, -10...15mm)
HopeStarON360 (progenitor of the Suzuki LJ)
JeepAll CJ Jeeps ‘46 – ‘85 have 5x139.7 15” with either 4.5/5/6” rims (L offset)
Also Jeep full size trucks and wagons up to 1972; & C-101 Jeepster Comanando '67 to '74 (don’t mistake them for the 5x114 fitted to Cherokee/Wrangler and modern 5 stud Jeeps)
Jeeps (licence built):Mahindra (Jeep, India), Mitsubishi (Jeep’53 – ’98, Japan), Willys Colombia (Jeep –’99), Willys Overland do Brasil/Ford (Jeep ’54 – ’83, Brazil), Kaiser Argentina (IKA) (Jeep ’56 – ’78, Argentina), Türk Willys Overland (Jeep – ‘80s) Hotchkiss (Jeep ’54 – ‘70s, France), Nekaf (Jeep ’56 – ’62, Netherlands), EBRO (Jeep ’53 - ’85, Spain), Hadonghwan ('54-??, South Korea), Pars Khodro (Iran). All unconfirmed - certainly 5 stud, and very very unlikely to be anything else.
Ford M151 “Mutt” Jeeps ’59 – ’78 (unconfirmed - certainly 5 stud and likey to be based on the Jeep PCD; also they have a pretty H looking offset). Early MUTTs had cast mags (oval slots).
International HarvesterAll Scouts have 5x139.7
FordAll USDM Fords '28-'48 (?)
Mercury - all '39-'51
Post-WWII “Jailbar” pick-ups
F series trucks ’54 – ’95, 15 x 6 (L offset) (don’t mistake them for the 5x135s the ’96- F 150s had)
Lincoln - all '52-'60
Bronco ’66 – '96, 15 x 6 and 7, (L offset) (don’t mistake them for the 5x114 the Bronco II (’82 – ‘90) had)
½ ton E-100, 150 van, ’70 – ’96, 15 x 6, (L offset)
Econoline E150, ’88 – ‘94
ie you could fit the legendary Ford 9 inch diff - and keep stock rims!
Chevrolet / GMCTracker, Vitara (USDM) ’98 on, 15 x 6, 12mm X 1.25 (L/M offset, -10...15mm) (US rebadged Suzuki)
Niva 2 (re-badged Lada)
PontiacSunrunner (Canadian rebaded Suzuki) (L/M offset, -10...15mm)
Chrysler8 cyl. & wagon '46-'55
Imperial '54-'66
GeoTracker 2WD 1989-1998
ToyotaBlizzard (re-badged Daihatsu)
Landcrusier V8s are listed as 5x1.39.7s in Russia, but I suspect an error (ie actually 5x150 as the ‘Cruiser is listed in other markets, but who knows maybe their V8 'Cruisers have Daihatsu bits for some bizzare reason).
Delta Motor Corp (Phillippines)
Mini Cruiser (Daihatsu F20 based miniture version of the Toyota FJ40), (unconfirmed - certainly 5 stud, and unlikely to be anything else)
MazdaProceed (Japanese rebadged Suzuki) (don't confuse with non-Suzuki based Proceeds)
AZ-Offroad (Japanese rebadged Jimny) (L/M offset, -10...15mm)
MahindraScorpio (unconfirmed - 5 stud, and they make Jeeps so maybe...)
UAZvarious (ET 20, 106.0 mm, 6x15, 6x16)
LuAZvarious amphibian & utility models (unconfirmed, but they look right and were once owned by AvtoVaz/Lada), Offset High
GAZGAZ-69
Rolls Royce/BentleySilver Cloud/Phantom – the ultimate 18” ‘bling’ rims for a Niva if you can ever find a set.
Bertone FreeclimberDaihatsu based Italian 4x4 (powered by BMW!)
VolvoC202 & Valp L3314 models (not the C30 models which have an 8 bolt pattern) had 6.50-16" or 5.50-16" rims
SantanaVitara and 300/350 (Spanish rebadged Suzukis) (L/M offset, -10...15mm)
WillysPick-ups
Offset Guide:H = high or positive offset, typically +45, 40, 35mm (typically front wheel-drive)
M = typically + 20mm offset
L = low, typically 0 or negative offset
