H2OLOVA wrote:Negative of battery one to earth. Positive of battery one to negative of battery two. Positive of battery two to positive lead easy really
i found a diagrame on the net today with that, tryed it, turned the key, nothing, just melted the termanal a bit.
Bugger The battery may be farked Hook the batterys up as suggested above and see what happens. Depending on how long you had it connected etc etc you could have fried other stuff. Give it a go you've got nothing to loose as long as the batterys are connected the right way
