Pajero diff and pto winch
Ive got a 91 3L swb pajero, and trying to find electric diff lock for rear and PTO take off and winch
Re: Pajero diff and pto winch
I got the PTO output + lever + cables and first shaft..no winch..But i'm sure you have to change the gears in either the box or the drive gear in the pto..open to offers..good condition..This was out of a first generation and I'm sure they didn't make a second gen pto option..chers
Ok the rear diff lock is air - not electric. So when you track one down make sure you get the pump as well! and if you want it to work as per factory, the ECU to control it and the fancy switch. You cannot use any old pump as they operate at a very low pressure. Probably have to pay a few bob for one now.
The PTO winch's, they are available for gen 2's factory but they are very very rare - I have only ever seen two. The majority of them came factory on the 2.5 turbo diesel 1st generation paj's from 86 to 90 ish.
To retrofit one of these to a 2nd gen like a 91 model most likely is involves bolting up all the winch, incl PTO drive to side of the gearbox then taking the transfer case apart and swapping most of the internals over, you need to get the transfer case off the donor as well. So it is quite a job. Here are the results.
Glen
P.S. I have a rear locker for sale for a 1991-1994 3.0 V6. Don't ask me how much - but it is for sale depending on what is offered!
Glen
glen, did he have a broken cv in that vid or somthing?
speaking of cv's...i have a set + axles + turbo's alternator,starter motors..radiator,doors..lol
Big wrote:speaking of cv's...i have a set + axles + turbo's alternator,starter motors..radiator,doors..lol
for a gen 1 or gen 2? how much you after fro the cvs and axles etc? and radiator if its for a 3ltr gen 2?
Sam
All gen 1..make an reasonable offer and they're yours(front axle-diff head-and cv's)..I've had these for a long time for spares when I had my Pajero..now moved to the landcruiser..so of no use..Rad is from the diesel..it's in good nick..no rot just needs a good clean and paint it'll look like new..Doors are rust free..beit 1 has a small dent..can't remember if I have 2 starter motors or not..but there is def 1 there and the alternators..not even sure if the work..had them so long..lol(It took 5 pajero's to gather the parts over a 10 year period..lol)If I can work out how to post up a pic I would..lol
pm me and I can email you a base pic-box load of gen 1 paj parts..and you can make up your own mind..selling these to get some plasma..
im after gen 2 stuff. cheers tho.
sorry for the thread jack.
Sam
Sam
no sweat..but I do wanna ditch them..
