Sammy Carb breather trick
Posted: Sat Sep 27, 2008 7:06 pm
by mudbugga
Hi guys
My bro's sammy has got the ususal splutter under hard accel. I remember something about a real easy mod to do with a breather for the carb but can't remember what to do :oops:
Can anybody help please?
Re: Sammy Carb breather trick
Posted: Sun Sep 28, 2008 9:44 pm
by Submercer
There is a carby fix for the ones fitted to the American Sammys. I think our carb is different. Checkout AksFac on Zuwharrie.com
Steve.
Posted: Mon Sep 29, 2008 8:09 pm
by mudbugga
They had a different carb alright.
I remember we used to do something to them but it was a quite a while ago when I had my sammy. Never mind, worth a crack. Cheers
Posted: Mon Sep 29, 2008 8:17 pm
by Heath
There was a small pipe that you fit to the carb to bring the breather or whatever it was out into the flow of air (caused hesitation in unmodified carbs)
From zuhwarrie site
Engine hesitation:
The stock carburetor has a flat-spot around 3000rpm. This is caused by the drop in vacuum in the manifold through the vent hole in the secondary throttle plate, causing the secondary to not open properly. The simple addition of an inexpensive carburetor vent tube will cure this problem. This OEM part is available from several of the Suzuki aftermarket companies
http://www.izook.com/shoptips/vent_tube_fix.htm is the site for the kit and a write up also.
Hope it helps.
Posted: Mon Sep 29, 2008 8:38 pm
by mudbugga
Cheers Heath
I think that the NZ sammy's had a Asin carb. I'll check what's on it though when I see him next. Good be all good.
Posted: Tue Sep 30, 2008 1:52 pm
by UBZ
We ordered a Vent tube off Rockey Road for my mates Sammy.
When we went to Fit it to the Asian Carb we found it all ready had one fitted.
Not sure if it came from factory like this or if it had been fitted later.
Posted: Tue Sep 30, 2008 2:10 pm
by Rotazuk
I fitted one from rocky road to my suzuki , it was an import one I think ( has two at the time and can't remember which one I had to put it into :oops: .
Chris
