thermo fan specs...
niblik
thermo fan specs...
Post by niblik »
well, i've got the rear mount styles radiator and i want to put a 16 - 18 inch electric fan onto it.. i realise ya get em from the usual outlet stores for around the $130 - $150ish range..
my question is a bit vague but try to stay with me, what sort of cfm does a standard cruiser viscous fan pull so i know what sort of cfm i'd be lookin for in an electric fan..?
yes yes, i realise more is gooderest but i gotta know where to start huh? :mrgreen:
any other suppliers got a decent range of these elec fans?
any light given upon this subject would be much apreciated.. :mrgreen:
Re: thermo fan specs...
I dont have the answer to your question but I'd reckon a std Cruiser fan would shift shitloads more cfm than as many electric fans as you could stick all over that radiator would so I guess you want to go for as much as you can with the electric fans :mrgreen:
Jafa
Post by Jafa »
and get a shroud built for it so that all the air possible is being sucked through the rad
021 273 9942
jafa@inspire.net.nz
Jafa wrote:and get a shroud built for it so that all the air possible is being sucked through the rad
hahahahaha
I can't wait to see what style of shroud you're gonna build nibby, should be huge to make it to the back :roll: :lol:
I put a commodore electric fan on mine, seemed to drag enough air thru to keep it cool, unless you were thrashing it for a long time :wink:
Jafa
Post by Jafa »
skid wrote:hahahahaha
wtf? :shock:
I meant like this.........
Dont just attach the fans to the core, otherwise the air is only being sucked thro the smaller area of the fan, spaced out on a shroud pulls air thro over the whole core
021 273 9942
jafa@inspire.net.nz
wtf? :shock:
sweet dude :oops: :oops:
I figured you had some cunning plan in mind 8) 8) 8)
niblik
Post by niblik »
yeah, spotted your set up jaf..... thinkin shroudin is the only way to roll, just tryin to sort the fan thing so i can fab up this shroud to fit the fan..
cheers chaps..
right, anyone got an elec fan from a commy they wanna flick me? :mrgreen:
wopass
Post by wopass »
niblik wrote:yeah, spotted your set up jaf..... thinkin shroudin is the only way to roll, just tryin to sort the fan thing so i can fab up this shroud to fit the fan..
cheers chaps..
got one yep,shroud and all. think it works.... not sure, will check tomorrow night .
if ya need it ill send it down bro.
:mrgreen:
wjw
Post by wjw »
When Rick did research for fans on my truck, he found the electric commodore fans shifted the most air, 4400 CFM. The aftermarket one I bought, which is the common one people buy does a max of 1750. It used to get REAL hot before I changed fans. And I still haven't got around to making a shroud... Last one I bought cost me $30. If you use one make sure you have a spare as the motors need a good clean every so often.
I have a spare one... so if you in a rush ... wopass can send me his (if it works) and I'll give you mine.
Wopass it is the one where the motor mounts with three screw eh?
Who knew Prados could fly?
niblik
Post by niblik »
cheers chaps..
:mrgreen:
wjw wrote:I have a spare one... so if you in a rush ... wopass can send me his (if it works) and I'll give you mine.
awesome chaps... thanks heaps.. *insert good shit icon*
aroma
Post by aroma »
Ive got three or four fans in the shed I only need one if you want to come and have a look a comm one there from memory
03 9421069 hm i'm in linwood or 0274913440
Warren :D
wopass
Post by wopass »
Ummm... i kinda forgot about the fan, was to busy playing with my son. can check it friday arvo if still needed bro?
Doh :oops:
niblik
Post by niblik »
wopass wrote:Ummm... i kinda forgot about the fan, was to busy playing with my son. can check it friday arvo if still needed bro?
Doh :oops:
sweet as fella...
Return to “Tool Shed”
