4/5th Oct
Posted: Fri Oct 03, 2008 10:13 am
by curly12
Well end of the working week for me and about to head home to fix the hubs on the Whale.
It has auto/ manuel locking hubs and the auto part is worn out. Even when locked up they click in and out. :roll:
However I have been told that if you remove the auto part of the hub, you can use it as a standard manuel locking hub and it won't keep unlocking itself.
Guess i will find out if it works tomorrow arvo when i get to Rallwoods :wink:
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 12:08 pm
by gazza
curly12 wrote:Well end of the working week for me and about to head home to fix the hubs on the Whale.
gonna make sure i,m not behind you on a hill then :shock: :shock: :shock:
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 12:54 pm
by tgaguy1
Make sure there is no grease in them. They don't like grease and have the symptoms you are describing when grease is present. A light coat of oil only.
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 3:43 pm
by coxsy
tomorrow reassemble a 40 front axle another $400 for new brake calipar :(
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 5:32 pm
by wildplumdx
they dont like grease in them ? where about you mean on the hub coz i just puled mine off to change the disks and greased mine up as the old grease was knacked i' guessing you mean between the hub cap and the hub itself that area ? coz i think i did :?
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 5:35 pm
by coxsy
this front axle
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 5:43 pm
by tgaguy1
wildplumdx wrote:they dont like grease in them ? where about you mean on the hub coz i just puled mine off to change the disks and greased mine up as the old grease was knacked i' guessing you mean between the hub cap and the hub itself that area ? coz i think i did :?
Inside the FWH, on the auto cam and locking splines. Obviously you need grease in the wheel hub, just not the free wheeling hub.
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 5:56 pm
by coxsy
well on luck on the 40 as it a nightmare of bad engineering
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 8:11 pm
by basics
sorted out the breaks on the cruiser, now gota find a lose conection some where, turn the key and nothing happens. but all the lights go, so the power is there.
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 8:15 pm
by haynzy
basics wrote:sorted out the breaks on the cruiser, now gota find a lose conection some where, turn the key and nothing happens. but all the lights go, so the power is there.
main fuse?
Re: 4/5th Oct
Posted: Fri Oct 03, 2008 8:21 pm
by basics
main fuse?
wish it was that easy, i cant find anything simple, so will have to pull all the plugs and have a fiddle.
its been sitting for 6 months so maybe that has somthing to do with it
Re: 4/5th Oct
Posted: Sat Oct 04, 2008 4:14 pm
by xj
2nd attempt at this..... damn fandangled technology!
Took the 33's off the stock rims on the brides TJ and popped em on the new, matt black mangels.... and i rekon they look farking mean with only a 2 inch lift. Sure the flares are going to cop a flogging when the suspension is flexed, but what the hey!
Then, cranked up the front of mine and took out the stoooopid spacer that had the front up at a 5 inch lift and the rear at 4. Re-aligned the front and rear track bars, and then got the draglink centred also. Drives a damn sight better on the road now, no crabbing to the left and a heap lesss "float".
What to do on the brides one next.....??????? Body lift, winch, discos.... hmmmmmmmm
Re: 4/5th Oct
Posted: Sat Oct 04, 2008 5:53 pm
by cruzerboy
Got my 37s today put them on the cruiser looks mint :D
Re: 4/5th Oct
Posted: Sat Oct 04, 2008 7:28 pm
by skid
cruzerboy wrote:Got my 37s today put them on the cruiser looks mint :D
Re: 4/5th Oct
Posted: Sat Oct 04, 2008 7:30 pm
by zookfest
went and got 2 cans of high heat matt black and put them to good use on the truck :lol: ,then went thru lyttleton tunnel sounds awesome 8) ,also went and had a look at another 300zx
Re: 4/5th Oct
Posted: Sat Oct 04, 2008 9:26 pm
by cruzerboy
will put some pics on 2mro haven taken any yet and i figer out how 2 put pics on here
Re: 4/5th Oct
Posted: Sun Oct 05, 2008 6:00 pm
by Pedro
wired up the jeep, lockers, computer, dash etc, got the jeep tuned on the megasquirt, easy when you figure it out, got brakes bleed, bonnet fitted, inner guards glassed and trimmed, seat and belts fitted, redid exhaust as it was bloody noisy, it could be heard clearly 2 streets over i found out at the end of tuning session, list is down to a A4 sheet with 4 days to go, no pressure..
Pedro
Re: 4/5th Oct
Posted: Sun Oct 05, 2008 6:44 pm
by Sadam_Husain
Had to take the little Flexi Fan Jnr off my truck and put a new fan on after getting told off by Sig :oops: :oops:
The new motor generates a bit more heat so I stuck a viscous fan on with blades that are a shit load bigger than the little Flexi Fan Jnr and fark what a difference, when I started the truck up in the shed before I put the new shroud on it there was newspapers and plastic bags and dirt and crap and rubbish blowing all over the place so its definately moving a shitload more air than the old fan was :oops: :oops: :lol: :lol:
When I took the truck through the aka's and back with Fweddys group today, the hills and slow congested moving that would have usually had me up at boiling over temp, I was staying down to just under 1/4 on the gauge so she's cooling real nicely now :mrgreen: :mrgreen:
Re: 4/5th Oct
Posted: Sun Oct 05, 2008 8:57 pm
by mickey
hey sadam, are you using the stock cruiser radiator?
Re: 4/5th Oct
Posted: Sun Oct 05, 2008 8:59 pm
by Sadam_Husain
mickey wrote:hey sadam, are you using the stock cruiser radiator?
Yep standard petrol 3f 4 core radiator
Re: 4/5th Oct
Posted: Sun Oct 05, 2008 9:51 pm
by mercutio
did some more stuff on the g got the engine sitting in place was hoping to have it bolted in but things are fowling a bit especially on the left hand side around the intake manifold will post some pics in my build thread tomorrow night
Re: 4/5th Oct
Posted: Sun Oct 05, 2008 9:58 pm
by TJ
xj wrote:What to do on the brides one next.....??????? Body lift, winch, discos.... hmmmmmmmm
I thought you were selling that one! What happened? BTW, like the look of the rims. Where did you source them from?
Re: 4/5th Oct
Posted: Sun Oct 05, 2008 10:50 pm
by xj
I was, but no-one was prepared to part with the reasonable amount i was after, and i want prepared to give it away.... so the new project begins.....
Rims are courtesy of another Jeeper that had them sitting in his shed, they were a bit banged up so some primer and some engine enamel and they came up good, i dont suspect theyll stay looking like that for long though. Looking at trying a different angle on flare extensions next week. Ill trial it on my one first, and if it comes up ok ill do it to the bosses one too. rather than buying the 7inch replacement flares, im going to cut the vertical plane off, and attach a strip of conveyor material to the remaining horizontal plane. Although Ill lose the side indicator.
Re: 4/5th Oct
Posted: Wed Oct 08, 2008 12:01 am
by TJ
xj wrote:Looking at trying a different angle on flare extensions next week. Ill trial it on my one first, and if it comes up ok ill do it to the bosses one too. rather than buying the 7inch replacement flares, im going to cut the vertical plane off, and attach a strip of conveyor material to the remaining horizontal plane. Although Ill lose the side indicator.
How about something like this for side indicators and flares?
Re: 4/5th Oct
Posted: Wed Oct 08, 2008 4:47 pm
by xj
They look like modified stock ones. Still wouldnt help my width issues. I think i might just bite the bullet and get the wifes wagon the real mcCoy and butcher my ones.... otherwise i can just see a right clusterf**k happening.
