Wiring the 40
jumper
Wiring the 40
Post by jumper »
What the best way of hooking up a 100 amp cable to a 8 terminal fuse box ? How do you split the cable to all the terminals ?
microwaved cheese on toast
dazza85
Re: Wiring the 40
Post by dazza85 »
The best way that I have seen is to bend each one 90 degrees so that they touch each other and solder the cable across them.
FUBAR_nz
Re: Wiring the 40
Post by FUBAR_nz »
100 amp into fuse box? or 100 amp into fuseable links?
what sort of mounting terminals?
bolts or push on termianls?
bolts make a steel plate (stainless,brass etc) looks like an E that has holes on each leg for bolts, eyelet terminal on cable and bolt to gether
push on terminals loop it so it goes so it looks like a m
Return to “Tool Shed”
