Jeep cj8 forsale
Posted: Mon Oct 06, 2008 10:34 am
http://www.trademe.co.nz/Browse/Listing ... =180963661
In Auckland 027 257 3757
$6500
Jeep ... A beast of a truck! Great 4wd for offroad use!
This is the perfect 4x4 for someone who likes to play in the outdoors, wants a off road club truck, or just wants a beast that will turn heads where ever you go.
* Amc 304 c.i. V8 (factory jeep engine from cj7)
* Wof and Rego till dec 2008
* Certified for modifications
* Power steering added
* Spring over axle conversion
* 2 inch body lift
* 36 inch super swampers
* Detroit ez locker in rear
* 4 wheel disc brakes
* MR2 bucket seats
* Roll bar in Tray
* Removable hard top
* 4 speed gear box
* Custom made bull bars and front guard protection
* Winch mount
* Rated Tow hooks front and rear
* Professionally shortened rear tray(certified)
* Dana 44 diffs
* Fully rebuilt Dana 20 transfer case, using new gears imported from USA
* New Shocks
* Twin shifters added to transfer case
* Electric ignition
* Electric fuel Pump
* Electric fan
* manual locking hubs
* in cab winch controls
This truck looks awsome on its huge tyres and massive lift, the roar of the V8 makes the truck sound as good as it looks. The addition of power steering makes this truck fun and easy to drive!
Previous owner rebulit engine less than 10 000 kms ago. Winch avalible for additional purchase, and will sell for less without large tyres.
A HUGE amount of time and money has gone into this truck, needs a few things finishing off. Needs: a hand brake cable (broken one supplied), headlights switch hooking up, front drive shaft installing (supplied), detroit locker very noisey while driving on road (standard diff gears supplied) , transfer case 4wd shifter adjusting (a bit stiff).
Heaps of power from engine:
AMC 304 V8
Bore x Stroke 3.75" x 3.44"
Displacement 304(4.98L)
Compression Ratio 8.4:1
Horsepower (gross) 210@4400
Torque (gross) 300@2600
Main Bearings 5
Valve Configuration OHV
Fuel 2bbl
Body is straight and in good condition. Paint is average, but its a 4wd Larger radiator and electric fan work well, never had over heating problems.
$6500
* 2 inch body lift
* MR2 bucket seats
* Roll bar in Tray
* 4 speed gear box
* Winch mount
* Dana 44 diffs
* New Shocks
* Electric ignition
* Electric fan
AMC 304 V8
Main Bearings 5
Fuel 2bbl
