I have a beach buggy that I am in the middle of re-wiring, I have four 100W 12V spotlights on it that I want to wire up correctly and apart from that the only electrics it runs is an electric radiator fan and an electric fuel pump from a subaru leone.
I want to know if I run my spotlights in lots of two, i.e. one switch for the two inner spotlights and one switch for the two outer spotlights what amperage fuse should I run for each circuit?
I'm thinking something along the lines of (for each lot of two spotlights): +ve battery terminal > 20 amp fuse > 25 amp switch > two 100W 12V spotlights > ground.
Thanks in advance
